Wiper Motor
All things technical for Cutwater Boats. Post your questions and/or solutions for the Cutwater community here.
Wiper Motor
Postby mayzesd on Tue Aug 07, 2018 4:59 pm
The port side wiper was used recently and failed to shut off ,I also noticed that the Starboard side doesn't return to park
Cant locate the fuse in the park line anywhere ,checked fuse panel behind helm and no luck .
Any suggestions ?
mayzesd
City: Lantzville
State/Province: BC
Ranger/Cutwater Model: C-26
Vessel Name: MINIMIZER
Re: Wiper Motor
Postby knotflying on Wed Aug 08, 2018 6:37 am
I can't help you with the location of the fuse, but it sounds like you have two issues going on. The wiper that would not turn off may have an issue with the park cam contact. The park circuit is supposed to keep running power until the cam lobe opens the contact and stops power to the motor. This will always happen in the park position. You will have to remove the motor and open the case to inspect the contact. This is what probably blew the park fuse. Once the park fuse bows then the wipers will stop immediately when switched off regardless of what position they are in.
knotflying
City: Charlestown
State/Province: RI
Ranger/Cutwater Model: R-27
Vessel Name: (2011) Illusions
Re: Wiper Motor
Postby Carter7 on Thu Oct 11, 2018 10:55 am
Find great deals on eBay for Windshield Wiper Motor in Windshield Wiper System. Shop with confidence.
Carter7
City: munshiganj
State/Province: DC
Who is online
Users browsing this forum: No registered users and 2 guests
