Thruster stopped working
Questions posted here will receive a response from Cutwater Boats representatives
Postby tatoweb on Sun Oct 29, 2017 10:26 pm
Today I was using my stern thruster and suddenly it stopped working. When you push the stick either left or right, the led light flashes and if you are in the cockpit, you can barely hear a flickering sound, so obviously is not a broken shear pin.
Bow thruster is fine.
Any ideas?
tatoweb
City: DAVIE
State/Province: FL
Re: Thruster stopped working
Postby knotflying on Mon Oct 30, 2017 7:25 am
There is an entire troubleshooting guide, go here ---> http://www.imtra.com/Collateral/Documents/English-US/Products/SP_Troubleshooting_Guide_with_IPC.pdf This should help you to narrow down the issue. The Imtra people are also very helpful. I would first make sure you have good connections to the unit and then start working the trouble shooting from there.
knotflying
City: Charlestown
State/Province: RI
Ranger/Cutwater Model: R-27
Vessel Name: (2011) Illusions
Postby Steeldieman on Mon Oct 30, 2017 10:43 am
When mine stopped working this summer it was a blown fuse .
The thruster still made a noise when I tried to activate it.
They are anl tyype 150 amp. I’m not sure where they are located on your tug.
I have a c28
Steeldieman
City: Clarendon hills
State/Province: IL
Non-Ranger Model: Cutwater 28
Vessel Name: Katy A
Postby tatoweb on Mon Oct 30, 2017 11:44 am
Steeldieman wrote:When mine stopped working this summer it was a blown fuse .
I have a c28
I have a C28 too
tatoweb
City: DAVIE
State/Province: FL
Postby Steeldieman on Mon Oct 30, 2017 1:17 pm
ok , on the aft bulkhead where battery switch’s are
In the entry to quarter berth is a removable panel.
Remove that, mine are located up high. They are well marked.
The fuse is proprietary to defender but generic can be made to work until you can get the correct ones.
Let me know if that is what it was.
Steeldieman
State/Province: IL
Vessel Name: Katy A
Postby Cutwater28GG on Mon Oct 30, 2017 1:47 pm
also check the fuse on the thruster battery terminal itself
Cutwater28GG
City: seattle
State/Province: WA
Vessel Name: Living The Dream
Postby tatoweb on Mon Oct 30, 2017 11:20 pm
Steeldieman wrote:ok , on the aft bulkhead where battery switch’s are
I will. Thanks for your help
tatoweb
City: DAVIE
State/Province: FL
Postby tatoweb on Mon Oct 30, 2017 11:21 pm
Cutwater28GG wrote:also check the fuse on the thruster battery terminal itself
I think it can’t be, because the bow thruster won’t work also.
tatoweb
City: DAVIE
State/Province: FL
Postby Andrew Custis on Tue Oct 31, 2017 10:28 am
Hello,
If both thrusters are inop, the only thing common is the battery and grounding. What is your current battery voltage on your thruster battery and at each thruster unit?
Thank you,
Andrew Custis
Ranger Tugs & Cutwater Boats
andrewcustis@rangertugs.com
Andrew Custis
Ranger/Cutwater Factory Rep
City: Kent
State/Province: WA
Postby stwendl on Tue Oct 31, 2017 12:56 pm
Aren’t the control sticks powered too. I thought they get power from one thruster only. There some push buttons to enable the system. If the lights don’t come on then there is no power to all thrusters. Backtracking needed in case there is some inline fuse for he electronics in the panel
Difference between RVers and Boaters:
RVers move until they reach water, Boaters move until they reach land.
Ranger Tug owners can do both :)
stwendl
City: palo alto
State/Province: CA
Vessel Name: Cataleya
Postby knotflying on Wed Nov 01, 2017 6:53 am
If one follows the troubleshooting guide you will find the problem. Just follow the sequence , some of what is stated here and you will find the problem.
knotflying
City: Charlestown
State/Province: RI
Postby tatoweb on Wed Nov 01, 2017 1:29 pm
Andrew Custis wrote:Hello,
Thank you,
Bow works. Stern doesn’t
tatoweb
City: DAVIE
State/Province: FL
Return to Ask the Cutwater Factory
Who is online
Users browsing this forum: No registered users and 2 guests
