Cutwater28GG
- Jan 14, 2016
- seattle
- R-21 EC
- Non-Fluid Motion Model
- Cutwater 28
- Living The Dream
getting close to finally finish mounting my new takacat dingy!
This took longer then I had hoped for with 90 degree weather in Seattle causing glue issues! ( Waypoint marine did the glue work with my instructions on where to place it) glad they did it as they had to remove part of the manufactures name plate to get the pad to adhere.
so far looks good. just need to bend the weaver brackets to accommodate the angle of the standoff arms and we are done. I think with the weaver davits mounted on the outside rather than inside it gives me more height and should miss the wake.
the dingy is so light I can just grab the rope on the starboard tube and pull it up. No winch required. as a catamaran there is no floor to get punctured as the seperate inflatable floor rests above the water
