coreychamness
- Dec 30, 2013
- C-302 SC
- Tugs 'n Kisses
My first TruePower Combi (2500W) failed last June and was replaced with a new unit. Indications on the LEDs showed it charging but in fact it never did. It would not invert to A/c power either. Last weekend I was switching from charger to inverter in order to run a/c outlets while underway and the symptoms of last summer had repeated. I do not attempt to run the water heater but I do operate the microwave when needed. Today I removed the cover after disconnecting all power and discovered scorching on the inside. See the attached photo. I will now be attempting to get a new one via warranty. Has anyone else experienced this? It does get very hot in the port side aft locker where installed by the factory
