CO detector/alarm End of Life
Postby portlandtug25 on Wed Mar 13, 2019 2:25 pm
Hello All:
What I thought would be a simple unplug/plug-in swap of the Xintex Co detector ( in the cave) on my R25 SC, turns out to be a bit more complicated because the old unit (CMD-4M) is no longer available. The replacement unit ( CMD-5) doesn't have the 2-prong plug the old one has and is physically larger, has different mounting plate, etc.
Before I try to connect new wires to the 12v power supply to wire in the new one I'd like to know where the fuse is for this power supply and if there is anything else on this circuit. (the simpler way would be to just disconnect the original and mount a battery-powered unit close to the original )
Has anyone done this swap? Any advice? ( dumb question I
know--there's always advice on the Tugnuts.)
portlandtug25
City: Portland
State/Province: OR
Vessel Name: Regalo
Re: CO detector/alarm End of Life
Postby Red Raven on Wed Mar 13, 2019 3:02 pm
I just replaced my CMD-4 with the CMD-5 a month ago. Easy peasy, the screws mount in the same holes. You do have to crimp a new connection to the 12 volt wire with butt connectors. The fuse on our R27 is in the port cockpit locker in the auxiliary fuse block (the smaller one). Don’t know if it is the same on your R25SC. I have a laminated sheet with the fuse locations from Ranger Tugs that came with the manual. It was located per that sheet. 3 amp fuse.
Curt
Curt and Tracy Johansen
Red Raven
2014 R27
Volvo D3 200HP
Red Raven
City: Coupeville
State/Province: WA
Ranger/Cutwater Model: R-27
Non-Ranger Model: Sevylor Ocean Inflatable Kayak, Ranger 260 RIB
Vessel Name: Red Raven
MMSI Number: 338190767
Postby NorthernFocus on Wed Mar 13, 2019 4:25 pm
battery powered replacement
Dan
Never confuse confidence for competence.
NorthernFocus
City: Anchorage
State/Province: AK
Vessel Name: Divine Focus
Postby lbrown on Wed Mar 13, 2019 6:22 pm
I also use a battery powered detector
lbrown
City: Lucas
State/Province: KS
Vessel Name: Gabriela
Postby Larry H on Wed Mar 13, 2019 7:12 pm
Curt,
Thanks for the info. My CO detector reached EOL this past summer. I have the replacement and am going to install it soon. Now I don't have to look up the fuse location.
Larry H
2014 R-27
Jacari Maru
Larry H
City: Tulalip
State/Province: WA
Vessel Name: Jacari Maru
Postby Red Raven on Wed Mar 13, 2019 8:00 pm
Larry H wrote:Curt,
Good to hear from you Larry. Are you heading north this summer?
Curt
Red Raven
2014 R27
Volvo D3 200HP
Red Raven
City: Coupeville
State/Province: WA
Postby portlandtug25 on Thu Mar 14, 2019 6:36 pm
Thanks, everyone.I found my laminated diagram. It looks like there is nothing else on this circuit.
portlandtug25
City: Portland
State/Province: OR
Vessel Name: Regalo
Return to Chat
Who is online
Users browsing this forum: No registered users and 5 guests
