Battery life expectancy questions
Postby portlandtug25 on Wed Apr 03, 2019 4:08 pm
Hello All,
Some electrical advice would be appreciated.
Trying to decide if it's time to replace the factory AGM batteries In my R25 SC. It was delivered in June 2014 and has just under 300 hours. Only accessories driven by house batteries are the 12v refrigerator and rarely the Espar furnace and of course cabin lights. It's always plugged in to shore power in the slip and rarely do i go more than 2 days without shore power when cruising. Also have a solar panel from factory. On my last outing, after one day without shore power, I didn't have enough house battery to ignite the Espar heater the next morning. The refer was set at its lowest setting and it was not hot outside.. It was sunny the day before so I assume i was getting a little help from the solar panel.
So here are my questions:
1. Is 5 years a typical life span for the factory AGM batteries?
2. If I replace the house batteries (I think there are two of them), should I replace the starting and thruster batteries at the same time? Never any problems starting the engine and I use thrusters very sparingly.
3. How can I tell which batteries are which without disconnecting them?
4. If I replace any or all, what's the best replacement type? I like not having to check water levels , but maybe the AGM don't have the lifespan of a flooded.
Electricity is not my forte!
portlandtug25
City: Portland
State/Province: OR
Vessel Name: Regalo
Re: Battery life expectancy questions
Postby doke01 on Wed Apr 03, 2019 7:59 pm
1. In my experience typical life is 4-5 years on my 2007 Ranger Tug R-25 Classic for well cared for batteries
2. I only replace them when they start exhibiting signs of age (not retaining charge for the normal timespan for the most part). I replace the house batteries as a pair.
3. If the 25-SC didn't change, when facing the batteries, the two house batteries are on the right, the thruster is upper left, and starter on the lower left. Ranger changed a lot of things over the years on the R-25, so this might have as well. A 25-SC owner of that time period may have a better answer.
4. A loaded question I won't even begin to try to answer :)
Doug
Doug Kersten
Captain
Nauti Dream (2007)
doke01
City: W. Keansburg
State/Province: NJ
Vessel Name: Nauti Dream (2007)
Postby BaylorU on Wed Apr 03, 2019 8:24 pm
Following! My batteries are the originals (2012 C26, 4x 110ah AGM’s) and this past week they couldn’t run the microwave. Seems like they’re beginning to tire out.
Fair Seas,
Ken
For Going Slow: M/V Grace- 2012 Cutwater 26 (Trailer)
For Going Slower: S/V Dreamcatcher - 2004 Hunter 466 (San Diego)
BaylorU
City: Arvada
State/Province: CO
Ranger/Cutwater Model: C-26
Vessel Name: Grace
Postby Dale777 on Wed Apr 03, 2019 9:47 pm
Portlandtug25,
I suggest you review the FAQs at the following website - Northern Arizona Wind & Sun:
https://www.solar-electric.com/learning ... 0Batteries
I recommend this website since they have the expertise from selling and installing solar panels, charge controllers and batteries for storage of solar energy in the harsh environment of Arizona and regions beyond since 1979.
What you will find is that life span of deep cycle batteries in our boats varies greatly by these parameters: battery type, number of discharge cycles, and especially temperature and Depth of Discharge. So, there is no typical number of life span years when batteries in boats exist in all types of extreme conditions affecting these parameters.
A few months ago, I preemptively replaced all the original 5 year old AGM batteries in my R31S. I might have gotten another year or so out of them, but I did not want to potentially deal with dead batteries on an extended cruise with the attendant expense, headache and trip disruption.
Dale, My sister's art: http://www.cindydaunis.com/
My edit [] of: "The horn [ocean] stirs memories of fearful things, of powerful things, of noble and beautiful things!" by John Williams. https://www.youtube.com/watch?v=7gztnm6GS9M
Dale777
City: Ft. Myers Beach
State/Province: FL
Ranger/Cutwater Model: R-31 S
Vessel Name: TANGENT (2014)
Postby knotflying on Thu Apr 04, 2019 7:17 am
As others here have stated, battery life is related to how well they have been treated. Roam just replaced his after seven years. He has always been diligent with treating them properly and never had a full discharge. I have flooded and change them every three years, but with the cost of AGM I would wait much longer and not replace until necessary. Initially I would do a load test to indicate the capacity of the batteries. You will find that the engine and thruster battery will last longer than the house since they rarely get discharged. If replacing the house batteries always do both at the same time since one bad battery down the pike can ruin a good battery. Also, if you are using AGM with the engine and thruster stay with AGM with the house. Charger settings for different type batteries are different and you can't mix and match.
knotflying
City: Charlestown
State/Province: RI
Ranger/Cutwater Model: R-27
Vessel Name: (2011) Illusions
Postby NautiTug on Thu Apr 04, 2019 7:36 am
I believe you shouldn't be able to run the microwave on inverter/battery only. But correct me if I am wrong?
2017 Cutwater 28
No Reservations
Red Bank, NJ
NautiTug
City: Little Silver
State/Province: NJ
Ranger/Cutwater Model: C-28
Vessel Name: No Reservations
Postby tugnnaweigh on Thu Apr 04, 2019 9:44 am
All of this is really good advice, based on experience. If you want to do over again what you’ve done so far which is five years of boating battery trouble free replace all four and never look back!
My personal philosophy is to treat my batteries like the delicate roses they are and at the first hiccup around five years out they all go!
Here you tell who’s who in the zoo by photographing and drawing the connections prior to disconnecting anything.
What appears as spaghetti is actually pretty straightforward, ground going from negative to negative to boat ground all one color and red taking power to where it’s used, these often have a label on them near the battery. Perhaps a few black, fuzed lines carrying power to bilge pumps and smoke detectors and carrying current from the charger.
Perhaps it’s not quite as straightforward as I’m thinking it over.
Start off with newly cleaned and very very tight connections covered in grease and you’re on the way to another five fun battery trouble free years!
You are who we all want to be, a guy who apparently has never had to fiddle with his batteries and never has had his batteries fiddle with him!
Now, if you are as you say, unfamiliar with batteries and can find a boatyard that’ll swap them out for a couple hundred bucks; let ‘em. Also, stick with AGMs.
Me, I’m very familiar with batteries and unless I’m standing tall just looking down on them I wear safety goggles and a full face shield as problems with batteries can involve acid flying through the air.
Thinking it over, taking on four AGMs in a confined space is nowhere to cut your teeth on batteries, treat yourself to a nice lunch while someone else does it. Money well spent.
tugnnaweigh
City: San Luis Obispo
State/Province: CA
Vessel Name: Slippn Inn
Postby knotflying on Fri Apr 05, 2019 6:29 am
NautiTug wrote:I believe you shouldn't be able to run the microwave on inverter/battery only. But correct me if I am wrong?
I will run my microwave off the inverter, however, I will have my engine running so that the batteries do not get a major discharge. I also do that when using an electric coffee maker.
knotflying
City: Charlestown
State/Province: RI
Postby BaylorU on Fri Apr 05, 2019 8:25 am
My engine was running while trying to run the microwave, and my batteries had been fully charged (which may only be X% charged due to age). I would think that would be enough, even with the older batteries presumably putting out fewer bolts.
The microwave uses a max of 15A at 120V, or 150A at 12V, plus figure an extra 20% to compensate for energy lost in the inversion process. So let’s call it 180 total amps required to run the microwave for an hour.
That means to run the microwave (at full draw) for 5 minutes you need 1/12th of 180ah, or 15 total amps out of your batteries. I wouldn’t consider that a ”deep drain” at all....obviously the longer you run the micro, the more the drain.
It was just strange to me. I had nothing else drawing off the inverter at the time. And the moment we had shore power, the microwave worked perfectly.
Ken
Fair Seas,
Ken
BaylorU
City: Arvada
State/Province: CO
Vessel Name: Grace
Postby BB marine on Fri Apr 05, 2019 11:50 am
BaylorU wrote:My engine was running while trying to run the microwave, and my batteries had been fully charged (which may only be X% charged due to age). I would think that would be enough, even with the older batteries presumably putting out fewer bolts.
Ken
First question is what inverter is installed in your boat? 2000W, 1500W,1000W, What is the peak output and continuous output. If you have a microwave that has a max input of 15 amps a 1500w inverter will not provide enough amperage to operate the microwave. Even with new fully charged batteries. A 1500W inverter is rated for max output of 12.5 amps.
If you have a 2000W inverter with a battery bank 120 AH you will be able to run your microwave for about 30 minutes continuously.A 2000W Kisea inverter, wired to a 180AH battery bank will have no issue powering the factory installed (Cuisinart) microwave (1000w) or convection oven(1500W) with this inverter. A 1500W inverter would have no issue powering the microwave portion, may be marginal for the convection oven.
If you have marginal batteries 70% of rated capacity and have the engine running with a alternator output of 120 amps and your using a 1500W inverter it will output 12.5 amps
What microwave is installed in your boat that requires 1800 watts to operate?
We use our inverter for cooking, electric stove top, microwave, convection oven, coffee, toaster, crock pot, TV, hair dryer, electronic chargers, 12V/120V vacuum, air pump for our paddle board and RIB. We use power management and generally one breaker on at a time to eliminate inverter over load. ( I changed the wiring in the AC panel to all circuits available when using the inverter) This requires an awareness of power management. The inverter does have an auto overload safety shut down but I avoid testing it.. I also use the inverter to operate the circulation blower from the marine air unit. We have used this if cruising on a rainy day. It circulates the air when the cabin/pilot house windows are closed. ( it will not power the compressor) If I had room for a large battery bank I would have installed the Kisea 3000W ( 3000 W 6000w peak, 25.0 amp continuous output. This inverter would power the Air unit. It would require ( 4 ) group 31 batteries 100AH each along with the engine running to properly run the Marine Air without compromising the batteries.
I was interested in this topic because I am installing new AGM batteries. I have always used flooded, maintenance free Deka batteries made by EastPenn. My factory installed maintenance free Centennial batteries (house fail to hold a charge) (Thruster is marginal),( engine battery is still good). My use of house and thruster batteries with the inverter has prompted me to look at AGM D/P batteries. I tend to demand more and full cycle my batteries, more then most. Knowing what the average life expectancy of the AGM is and comparing to my usage will gauge if it was worth the extra cost. I purchased (4) NorthStar AGM batteries Group 27.
Brian Brown
Cutwater 26
PORT-A-GEE
portageelooper.blogspot.com
bkb_marine@msn.com
BB marine
City: Lemont
State/Province: IL
Non-Ranger Model: 26 Cutwater
Vessel Name: PORT-A-GEE
Postby Red Raven on Fri Apr 05, 2019 12:27 pm
Ken
Hi Ken,
You are correct that running the microwave for a short period does not amount to a significant amount of the total capacity. However, capacity is not the only thing that is affected as your batteries age. The internal resistance also goes up. When you draw that much current you get a significant voltage drop at the battery output. When the battery is new this drop may be more than a volt, when older it may be several volts. At some point the voltage drop is large enough that the input voltage is not sufficient for the inverter to produce the output demanded.
As an example, We can run the microwave off the inverter even without the engine running on our 3 year old AGMs. When batteries are fully charged with the microwave running via the inverter drawing 90 amps from the battery the battery voltage drops from 12.8 volts to 11.8volts.
Try measuring the battery voltage while the inverter and microwave is turned on. If the voltage drops too much your batteries may no longer have the capability to meet the need.
Curt
Curt and Tracy Johansen
Red Raven
2014 R27
Volvo D3 200HP
Red Raven
City: Coupeville
State/Province: WA
Non-Ranger Model: Sevylor Ocean Inflatable Kayak, Ranger 260 RIB
Vessel Name: Red Raven
MMSI Number: 338190767
Postby Chimo on Fri Apr 05, 2019 12:50 pm
The batteries that came with our 2017 R25SC are AGMs model 121100 from UPG. Each 110Ah. The specification sheet can be found at http://files.upgi.com:8086/UPGFileServi ... heet/45824.
What is interesting is the data on page 2 showing such things as temperature effect, SOC and open voltage and for me most important, cycle life vs depth of discharge. Depth and frequency of discharge obviously have a dramatic effect on life.
I have combined the thruster battery with the house bank through a switch (photo under 'modifications' in my album) for when I am out on the hook. I got the same numbers as Curt (who I always defer to on electrical matters ;) ) so I now always run the engine when I run the inverter for the microwave, coffee maker etc.. The alternator has a rating of 14V/180A but that won't be at idle. A Volvo tech told me to think around 140A at idle or about 1680W. Of course a chunk of that goes to the engine and parasitic loads but watching the battery voltage and power output on the 2000W inverter I see little voltage drop.
Chimo: a word of greeting, farewell, and toast before drinking once widely spoken in the Inuktitut language in northern Canada.
Chimo
City: Sidney
State/Province: BC
Vessel Name: Chimo
MMSI Number: 316033437
Postby BaylorU on Fri Apr 05, 2019 3:17 pm
I apologize, as I incorrectly said my microwave was 1500W. I was going off memory. It’s the factory-installed Cuisinart and so it’s 1000W as a microwave, 1500W as a convection oven, as stated above.
My guess is exactly what was being described above was what is causing the issue...voltage drop due to age is impacting it. The microwave will start, and a second or so into running will beep and shut down (when on batteries/inverter/engine running).
I have the 1500W TruPower inverter installed by the factory. It’s a fine unit.
The reason I was saying 1800 watts are required was because you do not get 100% efficiency when inverting from 12V to 120V. All inverters lose an amount of output during the process. I didn’t have the exact efficiency number for the TruPower 1500 when I wrote that, so I estimated 80% efficiency. I just looked it up and it’s actually 85% for all the TruPowers until you get to the 2500W + models, where it jumps to 90%.
Using 85% efficiency, to get 15 amps of 120 volt output, you’d actually need to draw 2,118 watts from your batteries, or 176.5 amps.
Here is the math (all assuming an hour of run time):
Desired Inverter Output of 120V Power: 15 amps x 120 volts = 1800 watts
Required Inverter Input of 12V Power (assuming 85% efficiency and pretending I have a 2000W inverter): 1800 watts divided by 85% efficiency, which is 2,118 watts from the batteries. 2,118 watts of power at 12V (for an hour) equals 176.5 amp hours drained from batteries.
Incidentally, the TruPower 1500’s rated “input amps” is only 150, which I’m wondering if depending on voltage could actually hamper its ability to produce its rated 1500 watts of output. If the batteries are outputting less voltage, simple math would show how quickly the inverter can be rendered incapable of providing its rated output. Later I’ll have to play around with that.
I think I’m realizing (this boat is new to me) that my 1500W inverter may not be capable of running at least the convection part of the microwave. Assuming my batteries are in good order, it should easily run the microwave if that only draws 10 amps of 120V power, but if the convection oven draws 15 amps, then a 1500 watt inverter is insufficient to handle that demand. The TP1500 does have a 3000W “surge” capacity, so it can certainly go over 1500W for a short time, but it’s really not designed to handle a 15A load.
In this case, if the voltage being output by my old batteries is low, it’s clear to me that’s why the microwave won’t run off the inverter.
Fair Seas,
Ken
BaylorU
City: Arvada
State/Province: CO
Vessel Name: Grace
Postby Chimo on Fri Apr 05, 2019 5:25 pm
BaylorU
Just for interest, what motor (I’m assuming outboard) do you have? What’s the alternator output at idle? Obviously not enough to bridge the gap with the battery output.
Chimo
City: Sidney
State/Province: BC
Vessel Name: Chimo
Postby BaylorU on Fri Apr 05, 2019 8:08 pm
I have the 4BY2 180hp Yanmar. The alternator produces 150amps, which is why it was surprising that the microwave wouldn’t work when the engine was running. I think it’s just because A) a lot of those amps go to running the motor (I’d love to know approximately how many amps the boat itself consumes just running the motor, if anyone knows) and B) because the rate of charge going into the batteries was still not enough to compensate for the lower voltage they were producing (or they were already fully charged and therefore the alternator wasn’t adding any additional amperage into the equation).
Would love to hear people’s opinions on that.
Ken
Fair Seas,
Ken
BaylorU
City: Arvada
State/Province: CO
Vessel Name: Grace
Next
Return to Chat
Who is online
Users browsing this forum: Cowichan and 10 guests
