Engine mounts
Engine mounts
Postby SparklePlenty on Tue May 14, 2019 4:38 pm
My 2016 25SC has 160 engine hours. A pre-season check found all four engine mounts loose- one so loose it could be turned with a finger. Although I have never noticed any vibration, the bolt that holds the exhaust support was broken, probably from slight vibration. All bolts are tightened and I will be tuned in to any vibration on a short cruise this weekend. I hope the alignment has not been compromised. As I understand, loose engine mount bolts are not unusual on Ranger Tugs.
SparklePlenty
City: Anacortes
State/Province: WA
Vessel Name: Sparkle Plenty
Re: Engine mounts
Postby Andrew Custis on Tue May 14, 2019 5:00 pm
Hello,
Thank you for sharing. Engine mounts settle in over time as the rubber softens and it’s not unusual to check the torque on these. This is something to check as well as alignments to keep up on the maintenance.
Andrew Custis
Ranger Tugs & Cutwater Boats
andrewcustis@rangertugs.com
Andrew Custis
Ranger/Cutwater Factory Rep
City: Kent
State/Province: WA
Re: Engine mounts
Postby Bosn Mate on Tue May 14, 2019 5:40 pm
Andrew:
Do you have torque specs on the engine mounts bolts and alignment procedures for my R29-S? If, not, where can I get them?
Thanks!
Mike
Bosn Mate
City: Cape May Court House
State/Province: NJ
Ranger/Cutwater Model: R-29 S
Vessel Name: Tingira
Re: Engine mounts
Postby Andrew Custis on Tue May 14, 2019 6:11 pm
Hello Mike,
These are actually listed in the Volvo installation and technical manuals for the engine. I’ll see if Tim can post these tomorrow for you.
Best regards,
Andrew Custis
Andrew Custis
City: Kent
State/Province: WA
Re: Engine mounts
Postby Bosn Mate on Tue May 14, 2019 6:18 pm
Thanks Andrew!
Bosn Mate
State/Province: NJ
Re: Engine mounts
Postby BB marine on Wed May 15, 2019 7:46 am
A preventative maintenance checking mounting lag screws and motor mount adjusting nuts for tightness should be done at pre-delivery, 50 hr check, and once a year. If a nut is found loose it is a good idea to check alignment. If the mounting nuts are tightened properly after alignment the nuts should not come loose. If the Lag screws are tightened and installed properly (Straight hole drilled in the engine stringer, right size hole drilled in the stringer, properly sealed hole with lag screw) the lag screw should not come loose. Unfortunately this isn't always done hence the need to check them. Because of the tight quarters in the compartment torquing is not really achievable at least in my C26 and many other boats that I have worked on. I use the term tighten it Milwright tight, as tight as you can get it. I use 2 different wrenches to tighten them properly 1) straight end and 45 degree opposite end and 2) 90 degree open end wrench.( Always back up the bottom nut) I have them in a tool box on the boat. I can post the size later (metric) "The bottom nut needs to be backed up when tightening the top nut".
As you can see from this illustration the only cause of the nuts loosening is not tightened properly. The last person that did alignment didn't tighten them properly. The mount settling or mount fatigue will not cause the mount nuts to loosen.
Alignment procedures are in general the same for all straight inboards google inboard engine alignment to get the procedure.
Proper alignment will put less strain on the mounts, less wear on packing and cutlass bearing and reduce wear on transmission components. Also give a much smoother operation through out all operating ranges of the engine.
Brian Brown
Cutwater 26
PORT-A-GEE
portageelooper.blogspot.com
bkb_marine@msn.com
BB marine
City: Lemont
State/Province: IL
Non-Ranger Model: 26 Cutwater
Vessel Name: PORT-A-GEE
Re: Engine mounts
Postby YukonRon on Wed May 15, 2019 10:36 am
I use a paint pen to put a line across each nut, bolt and mount assembly for a quick visual check if anything moves.
Ron & Barb
Whitehorse, Yukon
Yukon Ranger
2013 R25sc
YukonRon
City: Whitehorse
State/Province: YT
Vessel Name: Yukon Ranger
MMSI Number: 316023451
Re: Engine mounts
Postby Chimo on Wed May 15, 2019 5:20 pm
YukonRon wrote:I use a paint pen to put a line across each nut, bolt and mount assembly for a quick visual check if anything moves.
Our R25SC had the nuts marked from the factory.
Chimo: a word of greeting, farewell, and toast before drinking once widely spoken in the Inuktitut language in northern Canada.
Chimo
City: Sidney
State/Province: BC
Vessel Name: Chimo
MMSI Number: 316033437
Re: Engine mounts
Postby knotflying on Thu May 16, 2019 6:59 am
Check the bottom nuts also. I found one of my bottom nuts moved down a quarter inch. The top nut was in the tightened position, so technically there was no support below. My point is always check both nuts and don't assume everything is okay if the top nut looks correct.
knotflying
City: Charlestown
State/Province: RI
Ranger/Cutwater Model: R-27
Vessel Name: (2011) Illusions
Return to Chat
Who is online
Users browsing this forum: No registered users and 11 guests
