Underway AC
Underway AC
Postby Jfrano on Fri Jul 05, 2019 9:04 pm
On shore power AC1 both panels work fine. Underway, the panel with the ice maker, water heater, stove top doesn't turn on. Anything I should look at?
Jfrano
City: Butler
State/Province: NJ
Ranger/Cutwater Model: R-29 CB
Vessel Name: June Sea
Re: Underway AC
Postby Todd on Fri Jul 05, 2019 9:21 pm
Are you on generator or running inverter? Inverter does not power everything.
Todd
City: Clinton Corners
State/Province: NY
Ranger/Cutwater Model: R-29 Classic
Vessel Name: Coventina
Re: Underway AC
Postby Jfrano on Fri Jul 05, 2019 9:56 pm
I’m on inverter. I knew the engine wouldn’t
Power AC2 panel( Air conditioner) but this is 1 of 2 panels on AC1.
Jfrano
City: Butler
State/Province: NJ
Re: Underway AC
Postby BradOwens on Sat Jul 06, 2019 2:56 am
I don't know about the ice maker, but I think the water heater and stove top draw too much power for the inverter, so are probably not wired into the inverter circuit. That would explain why there are two panels for AC1. One for things that will run off the inverter, and one for things that won't.
Brad Owens
A boat is a hole in the water that you pour money into.
It's also a hole in the water that you get happiness out of!
BradOwens
City: Bothell
State/Province: WA
Vessel Name: Serendipity
MMSI Number: 367703440
Re: Underway AC
Postby Matty on Sat Jul 06, 2019 7:10 am
Looking at owners manual I can see the high amp items are separate from the other items such as outlets and fridge. They do this on purpose to increase battery life on a single charge when not moving or on shore power. Seems like it is working as intended - unless of course you think it worked before.
Matty
City: New Smyrna Beach
State/Province: FL
Ranger/Cutwater Model: R-27
Vessel Name: IN THE FALL (2018)
Return to Chat
Who is online
Users browsing this forum: No registered users and 8 guests
