Hit some logs and possible damage to prop and/or rudder
Re: Hit some logs and possible damage to prop and/or rudder
Postby baz on Mon Jul 15, 2019 11:26 am
My prop repair will be completed tomorrow at 10 AM. FYI... It was repaired by The Prop Shop, 3610 S Rd #100, Mukilteo, WA 98275 (425-353-5527) - https://propshopinc.com
The cost for straitening the two adjacent blades and performing a static balance will be $333. :) - about 1/10 the cost for a new prop. 8-)
I asked about applying a protective coating on the prop for inhibiting growth and lessening water friction and they said for the designed RPM range of the prop it was unnecessary; just have diver service clean the prop now and then would be sufficient.
Now to have the prop re-installed. :D
Barry & Jake-Wire Hair Fox Terrier
SOLD - 2010 R-25 LAXEY
Trade in 2016 Ranger Gray R-21EC LAXEY
Trade in R-27/OB, LAXEY, Hull Midnight Blue
2019 R29 CB NW Edition - IoM LAXEY, Hero Red
AIS 800, Radio Call Sign: WDK7354
Edmonds, WA
baz
City: Edmonds
State/Province: WA
Ranger/Cutwater Model: R-29 CB
Vessel Name: LAXEY
MMSI Number: 368083620
Postby SgtAlf on Mon Jul 15, 2019 2:35 pm
Great news! :mrgreen:
Tony & Kathy
R-23 Sea Holli
Jackson, NJ
SgtAlf
City: JACKSON
State/Province: NJ
Ranger/Cutwater Model: R-23
Non-Ranger Model: Sea Eagle SR14 W/15 Yamaha
Vessel Name: Sea Holli
MMSI Number: 338303803
Postby baz on Wed Jul 17, 2019 1:42 pm
The repaired prob was installed today along with a new prop zinc that will now not drop off. :D Trim tabs cleaned and bow and stern thruster zincs replaced as they were close to 50% gone.
Shared photo album here along with a photos of the stern thruster's old and new zinc.
https://www.icloud.com/sharedalbum/#B1AJOX8tMJP9V5S
Diver assured me the prop was installed the 'right way' and that throttle in fwd position WILL cause the boat to move forward. ;) 8-) :lol: Will find out for sure when I back out of my slip for a test run/spin.
Edmonds, WA
baz
City: Edmonds
State/Province: WA
Vessel Name: LAXEY
Postby ixlr8 on Wed Jul 17, 2019 1:59 pm
baz wrote:Diver assured me the prop was installed the 'right way' and that throttle in fwd position WILL cause the boat to move forward. ;) 8-) :lol: Will find out for sure when I back out of my slip for a test run/spin.
Isn't the prop/prop shaft tapered so the prop can only go on one way?
Jim
2018 RT-27 OB Claret Red "Maggie"
ixlr8
City: Cushing
State/Province: ME
Ranger/Cutwater Model: R-27
Non-Ranger Model: 2018 R-27OB w/Yam 300
Vessel Name: Maggie
Postby baz on Wed Jul 17, 2019 2:03 pm
Jim: Yes it is..... I was joking with the diver about this..... :roll:
Edmonds, WA
baz
City: Edmonds
State/Province: WA
Vessel Name: LAXEY
Postby Steeldieman on Wed Jul 17, 2019 3:09 pm
So how much all in did you spend? Did you get the zinc from the prop shop?
I was following a big tour boat about a hundred yards behind. I’m thinking maybe that wasn’t such a good idea, wonder if maybe something got churned up.
Steeldieman
City: Clarendon hills
State/Province: IL
Non-Ranger Model: Cutwater 28
Vessel Name: Katy A
Postby baz on Wed Jul 17, 2019 3:14 pm
Steeldieman wrote:So how much all in did you spend? Did you get the zinc from the prop shop?
The prop repair for the two adjacent bent blades plus a static balance was $333. On top of this will be what my diver service changes me for removing the prop and re-installing it. The prop zinc is not uncommon and my diver service always carries the one for my R29 CB model. They have a 'trick' to avoid the prop zinc from falling off prematurely and their 'trick' has proven to be flawless over many years servicing the RT models.
Edmonds, WA
baz
City: Edmonds
State/Province: WA
Vessel Name: LAXEY
Postby The Doghouse 2 on Wed Jul 17, 2019 8:41 pm
Barry, I'm glad the Prop Shop took care of you... they do really good work and they also a good place to look for a spare prop.
Your boat is "brand" new, yet that proprietary prop zinc can't be cheap and it was wasted. You've steered clear of galvanic isolators on previous boats, but your marina slip is definitely hot. Has the marina done a test recently "see" where your stray currents are coming from... I'm hoping the isolator I installed wasn't in vain!
Bob
The Doghouse 2
City: Lake Stevens
State/Province: WA
Non-Ranger Model: 2019 Hunter Green R27-OB w/ Suzuki 300
Vessel Name: The Doghouse 2
MMSI Number: 368050260
Postby baz on Thu Jul 18, 2019 12:10 am
Bob: The prop zinc fell prey to the retaining bolt either loosening and falling away, or the zinc material surrounding the retaining bolt's head had gone allowing the prop zinc to simply slide off.
I'm suspecting one of three things that must have happened
1) The prop zinc retaining bolt loosened and fell away allowing the prop zinc to slide off as a result.
2) The log collision somehow cause the prop retaining bolt and zinc to come off.
3) The zinc material surrounding the retaining bolt's head eroded allowing the zinc to fall away, and somehow the retaining bolt loosen and also fell away.
My diver service charges me $25 for the prop zinc and installation.
I have no faith in what my Marina tells me about their shore power testing. They tested several years ago and told me there was no issue. I also have no faith in a GFI protecting me as I tried that on my R25 Classic and it made absolutely no difference for me at Edmonds marina with the boat connected to shore power 100% of the time.
I eventually solved the issue in large part by only connecting shore power for 24 hours per week. This has resulted in my underwater zincs lasting from 9 to 12 months before they reach 50% gone. Prior to this my zincs would at 50% or less after 3 months.
Boat is kept in salt water all year round.
Edmonds, WA
baz
City: Edmonds
State/Province: WA
Vessel Name: LAXEY
Postby BB marine on Thu Jul 18, 2019 8:15 am
baz wrote:I have no faith in what my Marina tells me about their shore power testing. They tested several years ago and told me there was no issue. I also have no faith in a GFI protecting me as I tried that on my R25 Classic and it made absolutely no difference for me at Edmonds marina with the boat connected to shore power 100% of the time.
The galvanic isolator has limitations. It works in normal conditions quite well. The fact that you have always had issues with 3 different boats and had no results from using a galvanic isolator would indicate issues around the area that your boat is located.A galvanic isolator only protects against low level DC, up to 1.2 or 1.4 Volts, so if there’s some stray current issue in your marina, which creates a voltage higher than that, the isolator won’t do anything, but this would be unusual.
It sounds like the method you are using is the best way to protect the boat. It is not convenient but if that works for you its a good solution. I personally would have the water tested and try to find the culprit. Do other boats docked in the vicinity of your boat have issues too?
Brian Brown
Cutwater 26
PORT-A-GEE
portageelooper.blogspot.com
bkb_marine@msn.com
BB marine
City: Lemont
State/Province: IL
Non-Ranger Model: 26 Cutwater
Vessel Name: PORT-A-GEE
Postby baz on Thu Jul 18, 2019 11:48 am
The Doghouse 2 wrote:Barry, I'm glad the Prop Shop took care of you... they do really good work and they also a good place to look for a spare prop.
Bob
Bob: I don't understand why you have a GFI as you trailer your boat and for most of the time is not in the water ????????
Edmonds, WA
baz
City: Edmonds
State/Province: WA
Vessel Name: LAXEY
Postby The Doghouse 2 on Thu Jul 18, 2019 3:05 pm
I put new 2" pancake zincs top/bottom each trim tab prior to Poets Cove rendezvous this past spring... got home and I had more stray current patterning on the bottom zincs than I was comfortable with for the 5 days/4 nights we were moored. Although the zincs did their job, I decided a galvanic isolator might help... I want all the help I can get!
The Doghouse 2
City: Lake Stevens
State/Province: WA
Postby baz on Thu Jul 18, 2019 3:49 pm
Bob: how will you test the effectiveness of your GFI ?
Edmonds, WA
baz
City: Edmonds
State/Province: WA
Vessel Name: LAXEY
Postby The Doghouse 2 on Thu Jul 18, 2019 8:12 pm
Probably nothing more than visual inspection of the deterioration rate of zincs.
The Doghouse 2
City: Lake Stevens
State/Province: WA
Postby baz on Thu Jul 18, 2019 9:35 pm
The Doghouse 2 wrote:Probably nothing more than visual inspection of the deterioration rate of zincs.
Well that is not very scientific. You need to establish a baseline and measure from that. I went from 3 months and 50% erosion to 9 to 12 months with 50% erosion using my shore power on/off method.
Edmonds, WA
baz
City: Edmonds
State/Province: WA
Vessel Name: LAXEY
PreviousNext
Return to Chat
Who is online
Users browsing this forum: No registered users and 8 guests
