Recommended wrenches for stuffing box drip adjustment
Postby baz on Sat Jul 06, 2019 5:08 pm
Subject: Recommended wrenches for stuffing box drip adjustment
I've discovered I do not have the necessary wrenches for adjusting the drip rate from the stuffing box. What are the recommendations for these two tools ? I have a 2019 R29 CB. Thanks... :)
Barry & Jake-Wire Hair Fox Terrier
SOLD - 2010 R-25 LAXEY
Trade in 2016 Ranger Gray R-21EC LAXEY
Trade in R-27/OB, LAXEY, Hull Midnight Blue
2019 R29 CB NW Edition - IoM LAXEY, Hero Red
AIS 800, Radio Call Sign: WDK7354
Edmonds, WA
baz
City: Edmonds
State/Province: WA
Ranger/Cutwater Model: R-29 CB
Vessel Name: LAXEY
MMSI Number: 368083620
Re: Recommended wrenches for stuffing box drip adjustment
Postby Red Raven on Sat Jul 06, 2019 6:03 pm
I use two of these. A regular pipe wrench is too large in width.
[url]RIDGID 31305 Model E-110 Hex Wrench, 9-1/2-inch Offset Hex Wrench https://www.amazon.com/dp/B0009W9BT0/re ... iDb2EFZWTR[/url]
Curt
Curt and Tracy Johansen
Red Raven
2014 R27
Volvo D3 200HP
Red Raven
City: Coupeville
State/Province: WA
Ranger/Cutwater Model: R-27
Non-Ranger Model: Sevylor Ocean Inflatable Kayak, Ranger 260 RIB
Vessel Name: Red Raven
MMSI Number: 338190767
Postby baz on Sat Jul 06, 2019 6:12 pm
Thanks Curt.... just the info I needed. The shortish handles seem to be just the correct length for the limited space getting at the stuffing box nuts. :)
Edmonds, WA
baz
City: Edmonds
State/Province: WA
Vessel Name: LAXEY
Postby Trisailor on Sat Jul 06, 2019 6:47 pm
Hi Baz,
I've been using the same wrenches that Red Raven just mentioned. I recently had my cutless bearing replaced along with the stuffing box packing and have found these to be very useful in adjusting the stuffing box to fine tune the amount of drippage.
v/r Brian
Trisailor
City: Imperial Beach
State/Province: CA
Vessel Name: Fancy Nancy
Postby LMRanger on Sat Jul 06, 2019 6:51 pm
What size packing do you use? I have a R25SC , not sure if it would be the same.
LMRanger
City: La Mesa
State/Province: CA
Vessel Name: Puffin
Postby Trisailor on Sat Jul 06, 2019 6:59 pm
My stuffing box is on a 1.25 inch shaft. I thought the R25 ran the same shaft size. The stuffing box with the packing installed should seal around that size shaft. I'm not sure what size the packing is, I've just had to compress it to ensure it seals properly (3 to 5 drips per min). I do know the new packing that was installed is Teflon impregnated which helps with heat resistance.
v/r Brian
v/r Brian
Trisailor
State/Province: CA
Postby Brian B on Sun Jul 07, 2019 6:52 am
Here's a great article on the stuffing box and it's adjustment.
https://marinehowto.com/re-packing-a-tr ... ffing-box/
I purchased the packing material for my 25SC from Ranger Tugs, pretty sure it's 1/4" x 1/4".
Brian B
City: West Warwick
State/Province: RI
Vessel Name: GANSETT RANGER (2010) Yanmar 4BY2-150
Postby baz on Sun Jul 07, 2019 12:32 pm
Brian B: That is a very good reference article. Thank you. :)
Edmonds, WA
baz
City: Edmonds
State/Province: WA
Vessel Name: LAXEY
Postby Kenaithab on Mon Jul 08, 2019 12:31 am
Andrew wrote an excellent article with exactly the information you are asking for at the end of this factory bulletin. I wish they did more of these.
https://www.rangertugs.com/Userfiles/Do ... er-2015.pd
Kenaithab
City: Kenai
State/Province: AK
Vessel Name: Morning Glory
Postby baz on Mon Jul 08, 2019 12:41 am
Kenaithab wrote:Andrew wrote an excellent article with exactly the information you are asking for at the end of this factory bulletin. I wish they did more of these.
That link does not work.... gives
404 - File or directory not found.
The resource you are looking for might have been removed, had its name changed, or is temporarily unavailable.
Edmonds, WA
baz
City: Edmonds
State/Province: WA
Vessel Name: LAXEY
Postby Trisailor on Mon Jul 08, 2019 10:36 am
There's also a U tube video on the DIY page of the ABYC site.
https://abycinc.org/mpage/recreationalboaters
v/r Brian
Trisailor
State/Province: CA
Postby Bruce Moore on Mon Jul 08, 2019 12:20 pm
The f in pdf was dropped at the end of the url:
https://www.rangertugs.com/Userfiles/Do ... r-2015.pdf
Cheers,
Bruce
Bruce and Vicki
R-41 Bridge - Hull #4 - Soundtrack - Elliott Bay Marina, Seattle
Bruce Moore
City: Seattle
State/Province: WA
Ranger/Cutwater Model: R-31 S
Non-Ranger Model: SSBN 658 Mariano G. Vallejo
Vessel Name: Soundtrack
MMSI Number: 368096220
Postby baz on Mon Jul 08, 2019 12:22 pm
Thanks Bruce.... and yes I figured that out yesterday but for some reason it did not resolve the issue. Your new URL does resolve the issue for me. Thanks again. :) It's an excellent straight forward collection of information for dealing with the stuffing box drip rate issue(s). I have it archived and will be part of my boat's documentation....big thanks to Andrew for this. :D
I wonder how often this Factory News Bulletin is posted ? The referenced Bulletin is dated 2015!
I will be adjusting the drip rate (currently at around 40 drips per minute with prop shaft stationary) on my new R29 CB NW Edition (some 30 engine hrs at this time) later today, and will follow Andrew's instructions/advice. From my readings it's not unusual for an excessive drip rate on a new boat after a few hours of use such as mine.... the new stuffing material for a new boat simply needs time to adjust.
Edmonds, WA
baz
City: Edmonds
State/Province: WA
Vessel Name: LAXEY
Postby Chimo on Mon Jul 08, 2019 5:49 pm
Just as an FYI, I have about 270 hours on the boat and I’m at 5-6 drips/min. I’m thinking about first adjustment. Should I start a drop or two of WD40 on the threads in anticipation?
Chimo: a word of greeting, farewell, and toast before drinking once widely spoken in the Inuktitut language in northern Canada.
Chimo
City: Sidney
State/Province: BC
Vessel Name: Chimo
MMSI Number: 316033437
Postby Brian B on Mon Jul 08, 2019 5:55 pm
Chimo wrote:Just as an FYI, I have about 270 hours on the boat and I’m at 5-6 drips/min. I’m thinking about first adjustment. Should I start a drop or two of WD40 on the threads in anticipation?
PB Blaster is a much better penetrating oil than WD-40. I’d give it a liberal dose ahead of time.
Brian B
City: West Warwick
State/Province: RI
Next
Return to Chat
Who is online
Users browsing this forum: No registered users and 7 guests
