Low speed valve at high speed
Postby Cowichan on Mon Jul 08, 2019 10:04 am
Well, I’m quite embarrassed but I imagine I’m not the first. Yesterday I was leaving a marina at low speed, low speed valve engaged, and then I totally forgot to change back and I think it was close to an hour of running at 2850 rpm. Do you think there is any long term concern? A few weeks ago I changed the transmission oil.
Thank you!
Cowichan
City: Mill Bay
State/Province: BC
Ranger/Cutwater Model: C-30 S
Non-Ranger Model: Previous R25 SC, C 28.
Vessel Name: Kinship
Re: Low speed valve at high speed
Postby SJI Sailor on Mon Jul 08, 2019 10:15 am
During factory orientation (C30) we were told that it would automatically switch -- actually just ignore the low speed request -- once RPMs were high enough, so it would be a non issue. I don't have it with me at the moment but perhaps the engine manual would confirm that.
SJI Sailor
City: Seattle
State/Province: WA
Vessel Name: Make It So
Postby Shano on Mon Jul 08, 2019 12:25 pm
I suspect that it will be a non issue for the reason that SjiSailor mentioned but I suggest having a look and a smell of the transmission oil and compare it to some new transmission oil. Because the low speed valve is controlled by software it would only be reasonable to assume that there would be an RPM shutoff to protect the transmission. If the oil smells burnt or looks very dark then you should get it changed again and maybe call the dealer.
Shano
City: Delta
State/Province: BC
Non-Ranger Model: Cutwater 30S
Vessel Name: Great Catch
MMSI Number: 316034321
Postby Cowichan on Wed Jul 10, 2019 6:45 pm
Thank you SJI and Shano. You’ve given me a bit more confidence!
SJI I saw your other warranty post. I’ve encountered a few problems with my 2018 C30. The roof leak I had sounds like the one you had. Warranty has taken care of most things and the boat is great. I had an R25 and a C28 prior to this and for me the C30 was the best choice for me and my family.
Cowichan
City: Mill Bay
State/Province: BC
Postby SJI Sailor on Thu Jul 11, 2019 6:12 am
Thank you for the note and that is reassuring to hear about your C30 experience. We are looking forward to having it all resolved and then cruising much more. Cheers and see you on the water!
SJI Sailor
City: Seattle
State/Province: WA
Postby NorthernFocus on Thu Jul 11, 2019 9:01 am
We installed a Yamaha low speed valve. No concerns with forgetting to disengage etc. :D
Dan
Never confuse confidence for competence.
NorthernFocus
City: Anchorage
State/Province: AK
Vessel Name: Divine Focus
Return to Chat
Who is online
Users browsing this forum: No registered users and 7 guests
cron
