BB marine
- Feb 1, 2016
- C-26
- Non-Fluid Motion Model
- Grady White 208
- PORT-A-GEE
There have been threads asking how many hours do you have on your Tug or Cut? There have been threads asking what is your cruising RPM? There have been threads asking what is the highest RPM I can run my Volvo, Yanmar or Cummins at ? Threads about fuel efficiency, propping and speed performance. This thread is to combine all of them into one to see how Tug and Cut owners are operating their boats. What Tug and Cut owners are experiencing and expecting the reliability and longevity to be with diesel power plants installed and the way they are operating them.
We can ask a Volvo, Yanmar or MerCruiser representative, representing the company that manufactures and sells the engine. He is not going to tell you run it at 40 to 50% and you will significantly increase your longevity. Reason ? You will be upset at the boat manufacturer under powering the boat.
We can ask a Volvo or Yanmar or Cummins technician that works on the engines. Most of them are experienced at fixing oil leaks, component parts changing, troubleshooting day to day failures. There are not many that are tearing them down and rebuilding them. I have asked diesel technicians how should I run the D3? Most say run it hard! Diesels like to be run hard! I'll ask" even with an (open deck block) with high boost and high compression?" Sure Volvo says you can!
We can ask Fluid Motion technicians and customer service. They work with the selling engine manufacture to get the right engine that will achieve the advertised cruise speed and full throttle speed of the boat model. Unfortunately most of the Tugs and Cuts have to be run at 80% load to achieve those speeds. If you ask them what kind of longevity I can expect? They are perfectly honest, " you can run them at 90% of WOT, that is what Volvo is telling us and we are seeing good results" . Honestly that is really what they have to go on. Ranger Tug and Cutwater boats are one of the newest used boats in the Market. A 2008 model year boat is a fairly new boat in the used boat market. How many hours does a average 2008 boat have on it? 100 hrs a season average would be 1200hrs. Throw a couple of trips on the average boat use 12 year old boat may be 1500 hrs.
The small displacement diesels are built for the average recreational boater. Volvo, Yanmar and Cummins, run them at 80% load average 100 hrs a year you will get 12 or 15 years out of that engine easily.
Many Tug and Cut owners use their boats more than the average boater. Many use their boats year round. I know of a few owners that have over 1000 hrs on 2016 model year boats. I image there are many that do. That type of use is more than the average recreational boater. That is what this thread is about. I'm asking the boat owners not Volvo, not a diesel technician and not the Fluid Motion reps. How do you operate your Cummins, Yanmar or Volvo? What is your Max Rpm ? What Rpm do you cruise at and what is your fuel consumption at that cruise speed ? How many hours do you have on your engine ? Its not a debate or a right or wrong. Its a how do you run your boat?
My information
D3 220 HP 430 hrs +/- total,
slow cruise 2100 RPM
fast cruise 3400 RPM
Approximately 250 Hrs +/- 2250 rpm at or below average GPH 2.0. 180 Hrs +/- 3200 -3500 rpm average GPH 8.0.
My C26 runs best at 3650 rpm to 3700 rpm approximately 85% load. I rarely run that high.
Max rpm with the prop installed (17"X 17" 1.05" cup) high 4150 rpm and low 3980 fully loaded for a trip.
@2250 rpm average speed 8 mph. 7 kts. 2.8 gph
@ 3400 rpm average speed 14mph 12.2 kts. 8.7 gph
@ 3600 rpm average speed 16.5 mph 14.3 kts. 10.0 gph
@ 4130 rpm average speed 22 mph 19.1 kts. 12.0 gph
1150 rpm to gain 6 mph going from 20% load (estimate) to 70% load (estimate)
700 rpm to gain 8 mph going from 70% load " to 100% load. "
Reliability has been good with the exception of a Turbo hose and turbo failure at 400 hrs. I have all oil sampled after oil changes. Reports have come back within range each time. I did see higher iron count after taking a 700 mile trip and running most of the time at 3400 rpm my average iron particulates went fro 42 PPM to 64 PPM on this oil change 92 hrs. 64 hrs of run time total for the trip. The 64 ppm was on the high side of the range still considered ok. But advised to watch by Blackstone. I also had the reverse gear oil sampled when it is changed same time. This showed "Visible ferrous metal present in the oil sample. I was advised to resample in 75 hrs which I did and it was fine. My theory on this was higher rpm the wear increased slightly both engine and reverse gear. It would be interesting to see what others have experienced, reliability, Rpms , hours, Gph to get a better idea of what to expect from these smaller displacement diesels over time.
Sorry Yamaha and Suzuki powered Tug and Cuts you are in a different league with your 6000rpm engines cruising at 4000 rpm on a plane! It would be interesting to compare your numbers too.
I'm running out of things to do during this social distancing :shock:
My information
