neil":2tot65ep said:Thanks Knotflying..... I checked out all the reviews and ordered some gel.
I actually switched the other way. In the summer I leave the Pro Breeze running and it's quite effective for small quantity water removal. The temperature doesn't really fall below 15 deg C which is the real lower limit for a Peltier dehumidifier. The compressor types also get less efficient below 15 deg. and won't work below 5 deg. C but that gap between 5 and 15 deg. keeps me in a good range since the airflow and capacity are much higher. If you're interested there is an excellent explanation and comparison at https://probreeze.com/us/13-step-guide- ... umidifier/ .Alpina":1hok3uf7 said:neil":1hok3uf7 said:Thanks Knotflying..... I checked out all the reviews and ordered some gel.
What Knotflying is a good solution. A supplemental option is a non-condenser style dehumidifier such as the Pro Breeze models. They can run in temperatures below 60 degrees which standard dehumidifiers are not designed to do. Note that they are rated by cubic feet vs. square feet which makes them look much more powerful than they really are. I leave mine on 24/7 and during the months when it's too cold to run a standard dehumidifier.
Franco
