Best running speed?
Best running speed?
Postby Xhawk101 on Fri Dec 20, 2013 9:24 pm
I am a new owner of a 2009 25 ranger tug. It has the 150 hp cummins turbo. Max speed appx 18 mph. 3000 rpm about 13 mph. Seems to run a little hotter over 3k rpm. Wondering the best speed for cruising. Is it harmful to run 3000 plus rpm for extended periods?
I know 2000 rpm is way more efficient. Thanks for the input.
2009 ranger tug 25 classic
Xhawk101
City: Saint Petersburg
State/Province: FL
Non-Ranger Model: 33 capital yachts
Vessel Name: Seacotropic
Re: Best running speed?
Postby Todd on Sat Dec 21, 2013 5:43 am
Don't know about Cummins. Check owners manual. I have the Yanmar 260. Max RPM 4000 Max continuous power 3600.
Todd
City: Clinton Corners
State/Province: NY
Ranger/Cutwater Model: R-29 Classic
Vessel Name: Coventina
Postby Levitation on Sat Dec 21, 2013 6:41 am
Your QSD engine is rated for continuous operation at 3/4 throttle (look in the black cover Cummins/Mercruiser manual).
That is below 3000 rpm based on how the factory props the boat.
What exact temperature is the 'little hotter' you speak of and at what RPM and for what time period?
Mercury rates the engine a bit higher than Ranger's 150 hp.
http://www.mercurymarine.com/engines/diesel/qsd/
Is the sea chest strainer clean?
When was your sea water impeller changed?
When was your coolant/antifreeze changed? (a pita to do - I suspect I know the answer)
Pull the zinc out of the heat exchanger and shine a strong light in there - or use a borescope - and look for scaling or deposits. It may need to be cleaned.
Have you compared the gauge to an infrared temperature gun reading?
*** Do that at multiple throttle settings and make a graph comparing the gauge to the gun - take enough time at each throttle setting to allow the engine to stabilize***
What is full throttle RPM? Is your prop clean? Or dinged?
Is the bottom clean?
And you thought you could just ask a simple question and get away at that, eh grasshopper :mrgreen:
denny-o
R25 #115
Levitation
City: hemlock
State/Province: MI
Vessel Name: Charlotte Ann
Postby Xhawk101 on Sun Jan 06, 2019 9:57 pm
Thanks very much for the information. So it's actually a lot hotter, like 196 to 200 if over 65 or 75% throttle. Have had system cleaned, new impeller, etc. Maybe I should try new cooling fluid.
Sent from my SM-G965U using Tapatalk
Xhawk101
State/Province: FL
Postby NorthernFocus on Mon Jan 07, 2019 6:36 am
Xhawk101 wrote:Thanks very much for the information. So it's actually a lot hotter, like 196 to 200 if over 65 or 75% throttle. Have had system cleaned, new impeller, etc. Maybe I should try new cooling fluid.
Confused about this thread. It spans several years. So is the overheat situation only a recent issue and boat has been operating OK since 2013?
Design operating temperature for the engine is 176-185F but they don't specify at what water temperature that is achievable.
New coolant isn't likely going to make a difference but flushing the block might help. Which would also mean replacing the coolant but flushing the system is the key.
Dan
Never confuse confidence for competence.
NorthernFocus
City: Anchorage
State/Province: AK
Vessel Name: Divine Focus
Postby Xhawk101 on Mon Jan 07, 2019 9:25 am
Sorry for the confusion it's basically same recurrent problem I guess but worse recently perhaps warmer water in Florida contributory but it shouldn't be getting over 186 it sounds like.
I've already had the system flushed. I guess I just need to find a decent mechanic... Easier said than done.
Xhawk101
State/Province: FL
Postby captstu on Mon Jan 07, 2019 11:44 am
My R25 engine had a chronic overheat problem until I changed out the thru Hull, eliminated the elbow, and replaced the. Sea chest with a strainer, all 1 1/2”. Problem solved.
See shearwater-sailing.com for a full discussion.
Stuart Bell (561) 352-1796
stu@Shearwater-sailing.com
R-25 Shearwater IV
captstu
City: Delray Beach
State/Province: FL
Vessel Name: Shearwater IV
Postby NorthernFocus on Mon Jan 07, 2019 2:31 pm
captstu wrote:My R25 engine had a chronic overheat problem until I changed out the thru Hull, eliminated the elbow, and replaced the. Sea chest with a strainer, all 1 1/2”. Problem solved.
Along the lines of what I was thinking. The raw water intake system as designed/installed by the factory is marginal at best. But only having experience with It with 50 degree sea water temperature I didn't have any data to back up my opinion. I'd not place any bets on 80 degree water and above. Maybe some other Florida owners will chime in.
Dan
NorthernFocus
City: Anchorage
State/Province: AK
Postby chrispangaro on Mon Jan 07, 2019 4:26 pm
I have a 2008 25 with the 110hp. At over 80% max rpm temp would creep up. Sea chest setup is poor. By cleaning Seacrest cover I found that at higher rpm the engine intake was creating sufficient vacuum to pull air through the head, more or less depending on the dry bowl setting on the head. This would be evident after a hard run, looking at the sea chest with engine running revealed a mostly empty bowl although it started full.
Problem substantially resolved by putting a high quality one way or check valve in the sea water supply to the head. Bowl on sea chest remains full. I still think the strainer style through hull doesn't allow sufficient flow for WOT. Will resolve that next time boat is slipped by cutting grating off it.
Chris
chrispangaro
City: Lilyfield, NSW Australia
State/Province: Other
Vessel Name: Hercules
Postby Xhawk101 on Mon Jan 07, 2019 10:23 pm
Great advice all thanks! Makes more sense now.
Xhawk101
State/Province: FL
Return to Chat
Who is online
Users browsing this forum: Jfrano, Kaptajnen, The Doghouse 2 and 8 guests
