SGIDAVE
- Nov 24, 2008
- C-24 C SE
- Tug Tide (2013)
A while back there was talk of raw water and/or exhaust temp sensors/alarms.
I bought the Aqualarm from Defender.com sized for the 3/4" raw water hose. I installed the flow sensor inline AFTER the strainer...my thinking was that there would be less 'junk' passing through the sensor if it received raw water which had been 'strained.'
This is the installation:
The kit I ordered included an alarm buzzer and dash-mounted LED which glows red when there is no flow. The alarm circuit is powered from the ignition, so it buzzes like the low oil pressure alarm when the key is turned on before cranking the engine to start up. It stops very soon after the engine starts in most cases.
I have tested it by turning off the raw water valve...it IMMEDIATELY alarmed. I was impressed with how quickly it reacted.
Thus far I have about 10 engine hours with the sensor/alarm in place and it seems good.
Fair winds and good raw water flow,
david
david
