BB marine
- Feb 1, 2016
- C-26
- Non-Fluid Motion Model
- Grady White 208
- PORT-A-GEE
Living in the midwest with a boating season of 4 months gives me time to do upgrades. Here is a list of my 2018 winter upgrades.
-Converted raw water flush to fresh water flush (Raritan Head)
-Moved two house batteries and thruster battery to starboard aft compartment.
-installed fresh water flush for engine and engine compartment light
-Installed 2 outlets in V berth area, cable TV outlets and 24" smart TV, 12 Volt fan, 12v light in pilot house
- Anchor raw water wash down
-22 gallon reserve fuel tank for fuel polishing and added cruise range
-Outside air ventilation for alternator cooling and cooler air induction for Volvo. Engine compartment exhaust blower to reduce high engine compartment temperatures. Added a digital thermometer to dash that monitors engine compartment temperatures.
-I made wider drop fins so that trim tabs will run parallel with centerline of boat.
-Wet sanded, Turbo cut, final polish and waxed blue hull to reduce visibility of factory hull patches, scuffs, orange peel, and swirl marks.It looks better but the patches are still visible.
-Repaired and rerouted deck drain hoses to get better drainage and prevent over flow into compartments.
-Repaired fuel fill hose routing replaced hose after finding it crushed from bulkhead causing a 50% obstruction in flow
-Removed cave mattress and installed carpeting.
- Recalibrated fuel sender to accurate calibrations based on recommendations from a Volvo service technician.
We are ready to start the 2018 boating season. We hope to see some Tugs and Cuts in our travels this year.
