Mounting problem for Dinghy Motor on the R23
Have you customized your Ranger Tug or Cutwater Boat? Share your handiwork here.
Postby jagizzi on Mon Feb 12, 2018 5:49 pm
I bought a standard Sea Dog motor mounting bracket to go on the stern rail of my R23. The vertical space on the stern rail will not allow for the bracket to be installed. It is easy to cut the plastic bracket down to fit but because of its design that would seriously weaken the bracket to the point that I would not trust it.
I figure that someone has to have had success mounting a dinghy motor on a 23 so how did you go about it? I would like to mount the motor on the swim step rail but according to the installer I would have to cut the rail. I would prefer not to have to do that.
I had thought that I could buy a split "T" to go on the horizontal part of that rail but that was naive thinking on my part. There is a hinged T but that won't fit the bracket.
How have folks mounted their dinghy motors on the R-23?
Jim and Kelli Gizzi
Next Ten
2018 R23
NWesterly.com
Friday Harbor
jagizzi
City: Battle Ground
State/Province: WA
Ranger/Cutwater Model: R-23
Non-Ranger Model: R-23, July 3rd delivery, yippee
Vessel Name: Next Ten
Re: Mounting problem for Dinghy Motor on the R23
Postby Red Raven on Mon Feb 12, 2018 8:06 pm
The hinged Tee does require the plastic mount to be reamed out a bit. That’s what I did. The strength comes from the Tee and not the mount. It works fine.
Curt and Tracy Johansen
Red Raven
2014 R27
Volvo D3 200HP
Red Raven
City: Coupeville
State/Province: WA
Ranger/Cutwater Model: R-27
Non-Ranger Model: Sevylor Ocean Inflatable Kayak, Ranger 260 RIB
Vessel Name: Red Raven
MMSI Number: 338190767
Postby SgtAlf on Tue Feb 13, 2018 6:48 pm
I found this little do da. I bolted it to the motor mount and I will attach the bracket to the rail. My dingy motor is 12.5 pounds. I'm sure it'll work. I'll tell you in a month.
www.amazon.com/gp/product/B00FDXJ83Y/re ... UTF8&psc=1
Tony & Kathy
R-23 Sea Holli
Jackson, NJ
SgtAlf
City: JACKSON
State/Province: NJ
Vessel Name: Sea Holli
MMSI Number: 338303803
Return to Owner Customizations
Who is online
cron
