fishheadbarandgrill
- Jul 15, 2018
- R-29 Classic
- Non-Fluid Motion Model
- Sunfish; Vespa GTS 300 Super
- Sea Shanty
I recently installed 3 fans in my 2011 R29. 2 in the V-berth under the speakers mounted on the headboard and 1 in the Salon just above the Fusion Remote Control panel. For the V-berth I removed the speakers and used a simple splice connector to splice into the lighting circuit. I drilled a 1/4" hole for the fan wire to run behind the headboard. For the Salon, I tied into the light fixture that is mounted on the spice rack. Because there is no access to behind the rack, I drilled a hole in the top of the light fixture base, inserted a grommet and tied into the fixture wiring inside the base. There is plenty of room inside. Because all my lights are LED and the Caframo 757 direct wire fans only draw 0.4A, the existing wires (16AWG) were plenty big enough to handle the load. Pictures in my photo album.
