Submariner
Channel Surfing
- Feb 2, 2020
- Everett, WA
- Website
- www.letsgochannelsurfing.com
- R-27 (Outboard)
- FMLT2702C021
- Non-Fluid Motion Model
- https://tinyurl.com/yrv84xdm
- Channel Surfing
I've finally completed our solar panel upgrade on Channel Surfing.
400 watts, we now have our energy independence during boating season.
I have seen as high as 27 amps going to the house bank from solar.
I wasn't a believer in solar before. I am now. We just finished a 4 day cruise in the San Juan's for Puget Sound Spot Prawns fish'n season. I never connected to shore power. We are seeing over 2,000 watts a day (about 150 amps, daily). Our normal daily consumption is around 1,200 watts. We did have FANTASTIC weather this past week, but even in previous weeks looking at cloudy/overcast skies we still saw over 1200 watts a day.
After 4 days of no shore power our battery bank was down to 42% (-200 ah). Note, our Firefly G31's house battery bank, I will run them down to 20% regularly if need be. With Solar putting back in what we used, 42% state of charge after 4 days of use, I was quite happy with those results.
It's also important to note that we are heavy heavy users of electrical. I work from the boat. Charge my laptop, run the WIFI/LTE router all day, inverter runs all day. I'm on zoom meetings most of the day. Meanwhile, we put 160 Spot Prawns in the freezer each day to freeze our daily catch. We don't conserve electrical, we use what we want. We do, however, turn things off we aren't using.
Solar Upgrade
I removed the factory 160 watt polycrystalline panel.
I installed a pair of Sunpower 200 watt 23.7% efficient mono crystalline marine grade solar panels.
(They are the same width as the factory panel, and about 3 inches shorter!)
I ran NO new wires for this upgrade.
I upgraded the factory PWM solar controller to a Victron MPPT SmartSolar 100/30 controller.
The 12volt red/black pair that went from the solar controller to the engine battery are no longer used so I pulled the fuse on them.
I connected the port and starboard solar panels in series (not parallel). I have no shading problem up top, and I wanted the amps to remain low, and the voltage to go high (around 70 volts DC).
I've updated our photo gallery with current pictures of the complete set up as well as instrumentation showing real-world stat's.
http://www.tugnuts.com/gallery2.php?g2_itemId=79431
We also published a video on our YouTube channel about this upgrade. ("Let's Go Channel Surfing")
https://youtu.be/M_BzO5R1AD8
As an added bonus... the clamp on stainless brackets I used (Gemini Products) look great and hold the panels up off the roof rack about 2 inches higher. This provides more clearance for opening the aft hatches. And the solar panels cover the aft hatches entirely so if it's raining out, we can still open those two hatches without water running in.
The big con to this upgrade, I have little room up on the roof rack for a kayak or anything else to store. Having enough power was more important to us.
If you're looking to upgrade your house battery bank, consider solar as well. Maybe even consider upgrading solar first.
Solar Upgrade
