SGIDAVE
- Nov 24, 2008
- C-24 C SE
- Tug Tide (2013)
Recently I saw a pic in "sidetrack's" album showing how he moved his spot light to the higher level on the mast to reduce the glare off the bow rails.
So, I did that mod to my boat this morning. To get the project started, I brought the mast into the shop
I opened up the wiring harness. This is what I found
The spot light had orange, grey, and black wires; the all around light had white and yellow wires. The black from the spot light and the yellow from the all-around are merged to yield a total of 4 wires going to the plug.
Next I drilled (3) mounting holes and moved the spot light to it's new position. The metal has initial hardness but once I broke through the 'plating' the bits drilled through easily. I drilled 3/16" holes. There is an existing large hole that works for passing the cable with wires from the bottom of the spot light.
Then, I attached new wires to the light. I used heat shrink butt connectors as shown here
These three wires were bundled and covered with heat shrink for more moisture protection
The wires where then bundled into a 3/8" split loom.
I used 1/2" loom at the bottom where the All-around light's wires join together.
The final look:
And, most importantly, the all around AND the spot light still work! Yippee.
It was a fairly easy job as long as you have drill bits, heat shrink, tinned wire, butt connectors, and split loom material.
/david
The final look:
/david
