Rudder position Indicator- Garmin
Postby Kaptajnen on Sun Sep 02, 2018 5:24 pm
To either port tWe just took delivery of a new Ranger Tug 31-S.
Is there any way to Display the rudder position on the garmen screen?
I was told that the way to center the rudder is to turn the wheel all the way to port or starboard and then turn it 3 turns the opposite way.
To me that is a timeconsuming and rather quaint way to center the rudder.
Any suggestions?
Than ks
Claus & Thyrsa Jensen
Bainbridge Island, WA
Ranger Tug 31-S Akvavit
Kaptajnen
City: Bainbridge Island
State/Province: WA
Ranger/Cutwater Model: R-31 S
Vessel Name: Akvavit
Re: Rudder position Indicator- Garmin
Postby TexasEye on Sun Sep 02, 2018 7:47 pm
TexasEye
City: Athens
State/Province: AL
Postby Kaptajnen on Mon Sep 03, 2018 12:18 pm
Hello TexasEye.
Thanks for the link. Can you tell me how the Rudder Position is shown on the Garmin Display, after the sensor has been installed? What specific screen, i.e. engine or what?
Kaptajnen
State/Province: WA
Postby ixlr8 on Mon Sep 03, 2018 12:25 pm
Kaptajnen wrote:Hello TexasEye.
Based on info on the Garmin site, it pairs with the autopilot controller and shows up on that screen. This is some thing I am tempted to get, since I put the full enclosure on it is more difficult to see the engine position.
Jim
ixlr8
City: Cushing
State/Province: ME
Ranger/Cutwater Model: R-27
Vessel Name: Maggie
Postby TexasEye on Mon Sep 03, 2018 3:00 pm
Yep,
It is for the autopilot not the Nav System. Garmin should include this capability to their Marine Nav system capability
TexasEye
City: Athens
State/Province: AL
Postby Admiral S on Mon Sep 03, 2018 3:34 pm
ixlr8 -
Not sure the GRF sensor will work with your outboard. They are for inboard rudder tillers. I would give Garmin a call and see what they say.
Admiral S
City: Stony Point
State/Province: NY
Non-Ranger Model: Helmsman Trawlers 43 Pilot House
Vessel Name: Varka (2017)
MMSI Number: 338238995
Postby stwendl on Mon Sep 03, 2018 7:00 pm
It’s not as simple as buying the sensor and plugging it in. As I understand it and based on my equipment on my 2016 r27, the autopilot controller needs to have that extra port which mine has not. If you want to make a try n2k Sensor that plugs into the bus then you need a second device, chop of the connector and splice together. Or buy a different auto pilot controlle
Technically it’s irrelevant if you have OB or rudder. However, protecting that sensor on an outboard would require extra effort. There may be splash protected sensors available for such purposes that I don’t know about. As mentioned before, installing can be a pain, as i have done on a sailboat before.
There a few articles on this site explaining the installation in details
Difference between RVers and Boaters:
RVers move until they reach water, Boaters move until they reach land.
Ranger Tug owners can do both :)
stwendl
City: palo alto
State/Province: CA
Vessel Name: Cataleya
Postby Kaptajnen on Sat Sep 15, 2018 10:30 am
It is not as simple as buying the sensor and plugging it in. As I understand it and based on my equipment on my 2016 r27, the autopilot controller needs to have that extra port which mine has not. If you want to make a try n2k Sensor that plugs into the bus then you need a second device, chop of the connector and splice together. Or buy a different auto pilot controller.
That is what I discovered after buying the sensor and trying to have it installed in our new Ranger 31-S. Had to abandon the install and return the Garmin sensor to the dealer.
Kaptajnen
State/Province: WA
Postby Kaptajnen on Sat Nov 03, 2018 11:29 am
In order to add an AIS responder to our Boat, I installed a VESPER XB-8000 box.
It is equipped with a NMEA 2000 port, so I am considering trying to add the Garmin rudder sensor again. It would involve pulling a cable from the stern to the forward equipment bay under the instrument panel which could be a show stopper.
Any thoughts?
Kaptajnen
State/Province: WA
Postby BradOwens on Sat Nov 03, 2018 12:29 pm
Being used to having a rudder position indicator on Coast Guard ships, I thought it was something I would miss having on my R29. I have found however, that after three years of owning Serendipity, I get along just fine without one, and wouldn't waste time and money installing one.
Brad Owens
A boat is a hole in the water that you pour money into.
It's also a hole in the water that you get happiness out of!
BradOwens
City: Bothell
State/Province: WA
Vessel Name: Serendipity
MMSI Number: 367703440
Postby Tug Travelers on Sat Nov 03, 2018 2:22 pm
Kaptanjnen-
Hi, both John and I (Tug Travelers) have 2016 R31's and we have the garmin rudder angle Indicators. For us, it was just a plug in after the armature arm was mounted. Email me at jeff@tugtravelers.com and I will send you photos if you want.
On our display, both on the flying bridge and on the lower helm, the indicator shows up on our auto-pilot screen at the top as well as our primary nav screen (also at the top).
It is very handy to have and the install was not hard.
Jeff
Tug Travelers Guided Ranger Tug Flotillas
www.tugtravelers.com
Tug Travelers
City: Walnut Creek
State/Province: CA
Postby Kaptajnen on Sat Nov 03, 2018 5:57 pm
Jeff,
Just sent an email to you.
Claus
Kaptajnen
State/Province: WA
Postby Kaptajnen on Wed Nov 07, 2018 4:20 pm
After checking with Ranger Tugs, here is the word on installing the Garmin Rudder Indicator on our 2018 Ranger 31-S:
——————————— QUOTE————————
“With the system you have onboard you will need to buy the indicator which is the GRF 10 and also get an adapter that is the GRA 10. This will allow you to connect from your indicator to your NMEA backbone and send the information to your GHC 20 display.”.
——————————— END OF QUOTE————————
FisheriesSupply.com lists the GRF10 at $250. and the GRA10 at $200.00. Add the cost of installation and you are looking at a total of close to a thousand bucks.
Kaptajnen
State/Province: WA
Postby Scottfree on Wed Nov 07, 2018 10:20 pm
Sorry but I'm not understanding why the position of the rudder is relevant. It's never pointed where the boat is going except in dead calm at 1 knot.
Did I miss something?
Leon
Leon & Karen
Scottfree R29 Classic
Scottfree
City: West Kelowna BC
State/Province: BC
Vessel Name: Scottfree
Postby BobnDoc on Wed Nov 07, 2018 11:57 pm
Jeff
I,too just sent you an email re installation of a rudder angle indicator. Not sure if it went thru. Please send me the info so I can do the same. Thanks for presenting a straight forward commentary. I’ve gotten a number of discouraging responses when I have asked others. Bob rosemanbob@comcast.net
BobnDoc
City: Edmonds
State/Province: WA
Ranger/Cutwater Model: C-30 CB
Vessel Name: Salish Spirit
Next
Who is online
Users browsing this forum: No registered users and 5 guests
