Steering on R25
Steering on R25
Postby bob daily on Tue Nov 06, 2018 9:28 pm
Am looking at a R25 and was wondering if these boats come with mechanical, or hydraulic steering?
bob daily
City: Kennewick
State/Province: WA
Ranger/Cutwater Model: R-21 EC
Vessel Name: Scuttlebutt
Steering on R25
Postby captstu on Tue Nov 06, 2018 9:35 pm
My 2010 R25 has both hydraulic steering and autopilot. Seems to be fine
Stuart Bell
Ranger 25: Shearwater
(561) 352-1796
Stuart Bell (561) 352-1796
stu@Shearwater-sailing.com
R-25 Shearwater IV
captstu
City: Delray Beach
State/Province: FL
Vessel Name: Shearwater IV
Re: Steering on R25
Postby bob daily on Tue Nov 06, 2018 10:34 pm
Is the rudder controlled by a hydraulic ram or a mechanical push pull cable ?
IE does the R25 have a hydraulic pump to control the steering unit?
bob daily
City: Kennewick
State/Province: WA
Re: Steering on R25
Postby baz on Wed Nov 07, 2018 12:55 am
bob daily wrote:Is the rudder controlled by a hydraulic ram or a mechanical push pull cable ?
The rudder is positioned with an 'crank' arm controlled by a hydraulic piston.
Hydraulic pump - Yes it does have one.
Barry & Jake (Wire Hair Fox Terrier)
SOLD - 2010 R-25 LAXEY
Traded in 2016 Ranger Gray R-21EC LAXEY
Trade in R-27/OB, LAXEY, Hull Midnight Blue
2019 R29 CB Hero Red Est. Delivery Mar 2019
Edmonds, WA
baz
City: Edmonds
State/Province: WA
Non-Ranger Model: 2018 R-27 Outboard
Vessel Name: LAXEY
MMSI Number: 368005270
Re: Steering on R25
Postby TexasEye on Wed Nov 07, 2018 10:30 am
On a small boat, a compact hydraulic pump with integral hydraulic-fluid reservoir located at the steering wheel connects with sturdy nylon hoses below decks and in turn to flexible rubber hoses to a steering ram at the transom, which reliably turns the outboard(s) as one turns the steering wheel.
The pump is attached to the helm, the turning of the helm operates the pump, there is not a motor!
Am I correct Captain's???
TexasEye
City: Athens
State/Province: AL
Re: Steering on R25
Postby TexasEye on Wed Nov 07, 2018 10:32 am
TexasEye
City: Athens
State/Province: AL
Re: Steering on R25
Postby BB marine on Wed Nov 07, 2018 10:50 am
Here a picture of the Hydraulic steering ram and linkage to the rudder. The Helm is the Pump. If you have an auto-pilot it also has a hydraulic electric pump that over rides the Helm pump when using auto-pilot
Brian Brown
Cutwater 26
PORT-A-GEE
portageelooper.blogspot.com
bkb_marine@msn.com
BB marine
City: Lemont
State/Province: IL
Non-Ranger Model: 26 Cutwater
Vessel Name: PORT-A-GEE
Re: Steering on R25
Postby TexasEye on Wed Nov 07, 2018 11:10 am
BB marine wrote:Here a picture of the Hydraulic steering ram and linkage to the rudder. The Helm is the Pump. If you have an auto-pilot it also has a hydraulic electric pump that over rides the Helm pump when using auto-pilot
Thank you, Sir
I've been fighting with my helm unit since I purchased the vessel. I have notchy steering and hydraulic lag...filled it, purged it, cursed it...best results was the cussin', I think it may be the nature of the beast
TexasEye
City: Athens
State/Province: AL
Re: Steering on R25
Postby Chimo on Wed Nov 07, 2018 1:01 pm
You are correct :)
For interest, his type of system was (is) also used on larger vessels. In my very early days learning to be a marine engineer I worked on the Blue Funnel ship Priam shortly after delivery. If my memory is right this ship was 11-12,000 DWT. One of the jobs was to check what was called the telemotor system. Very similar to what we have on our Tugs but the wheel operated rams at the bridge that were connected to corresponding rams at the rudder. There was redundancy in the system in case a cylinder failed and we had to charge the system using a hand pump. No pumps meant low pressures and continued availability in case of power failure. I actually thought about that ship this week when servicing our R25SC. I remembered working around the 30,000 SHP diesel and thinking some places were really tight. Nothing, however, compared to changing the impeller on the Tug!! (Though I confess to being 40lbs heavier now ) ;)
Chimo: a word of greeting, farewell, and toast before drinking once widely spoken in the Inuktitut language in northern Canada.
Chimo
City: Sidney
State/Province: BC
Vessel Name: Chimo
MMSI Number: 316033437
Re: Steering on R25
Postby bob daily on Wed Nov 07, 2018 3:06 pm
Thank you all for the information, I'm trying to see how hard and costly it will be to install a cockpit helm station prior to making a offer on a R-25
Bob
bob daily
City: Kennewick
State/Province: WA
Who is online
Users browsing this forum: No registered users and 6 guests
