Wesbasto Diesel Heater noise
Postby Bpwicks on Mon Dec 24, 2018 10:32 am
I am the new owner of a 2011 R-27 Northwest edition with a Webasto diesel heater. Every time the heater starts up there is this regular knocking sound that the previous owner told me was the fuel pump and that when fuel was successfully pumped to the heater the knocking would stop.
However, the knocking is continuous during heater operation.
Is this normal heater/fuel pump operational noise? The heater itself seems to function great even in cold weather.
Brian
Bpwicks
City: Silverdale
State/Province: WA
Ranger/Cutwater Model: R-27
Vessel Name: Chubasco
Re: Wesbasto Diesel Heater noise
Postby jagizzi on Mon Dec 24, 2018 11:40 am
It is the fuel pump and while the heater is running it will be pumping fuel, hence the “knock”.
Jim and Kelli Gizzi
Next Ten
2018 R23
NWesterly.com
Friday Harbor
jagizzi
City: Battle Ground
State/Province: WA
Ranger/Cutwater Model: R-23
Non-Ranger Model: R-23, July 3rd delivery, yippee
Vessel Name: Next Ten
Postby BradOwens on Mon Dec 24, 2018 12:55 pm
I'm curious what you mean by "knocking". On our R29 the Webasto fuel pump makes a soft ticking sound every one or two seconds. If yours is making a loud noise, or if it's not regular in its rhythm, it may be something else.
Brad Owens
A boat is a hole in the water that you pour money into.
It's also a hole in the water that you get happiness out of!
BradOwens
City: Bothell
State/Province: WA
Vessel Name: Serendipity
MMSI Number: 367703440
Postby baz on Mon Dec 24, 2018 3:44 pm
If there are are 'knocking' sounds surely they are drowned out while the boat is underway. The 'knocking' is normal as the pump primes the heater ready for combustion but should subside or quit once the heater is fired up and producing heat.
The most noise for me comes from the outside heater's vent and can sound like a supersonic wind tunnel running. In my covered slip this 'wind tunnel' noise gets amplified and passing people get very curious/excited about it. :lol:
Barry & Jake-Wire Hair Fox Terrier
SOLD - 2010 R-25 LAXEY
Traded in 2016 Ranger Gray R-21EC LAXEY
Trade in R-27/OB, LAXEY, Hull Midnight Blue
2019 R29 CB IoM LAXEY, Hero Red Delivery Mar 27, 2019
Edmonds, WA
baz
City: Edmonds
State/Province: WA
Ranger/Cutwater Model: R-29 CB
Vessel Name: LAXEY
MMSI Number: TBD......
Postby knotflying on Tue Dec 25, 2018 10:28 am
My experience is a bit different than others. I get the "sound" every time heat is required and the pump kicks in. This has always been normal operation for me.
knotflying
City: Charlestown
State/Province: RI
Vessel Name: (2011) Illusions
Postby KennyMarrs on Thu Dec 27, 2018 2:27 pm
Hello All,
The fuel pump will run the entire time the heater is in heat mode. If the Webasto is in vent mode the fuel pump will not be on but the fans will run. So, in vent mode you shouldn't hear the ticking sound as I call it.
Hopefully this helps!
-Kenny
KennyMarrs
Ranger/Cutwater Factory Rep
City: Kent
State/Province: WA
Vessel Name: The Buffalo
Who is online
Users browsing this forum: PACA1953 and 3 guests
