SPX Bilge Alert High Water Alarm
Postby Bosn Mate on Sat Dec 29, 2018 4:24 pm
Good Afternoon:
Does anyone know the location of the high water alarm on the 2018 R-29S?
Thanks!
Mike
Bosn Mate
City: Cape May Court House
State/Province: NJ
Ranger/Cutwater Model: R-29 S
Vessel Name: Tingira
Re: SPX Bilge Alert High Water Alarm
Postby ethanbarnett on Sat Dec 29, 2018 4:35 pm
On the 2015 it is to the right of the helm next to the engine start bottoms.
Ethan and Tammi Barnett on Liberty
ethanbarnett
City: Clearwater
State/Province: FL
Vessel Name: LIBERTY
Postby Bosn Mate on Sat Dec 29, 2018 6:20 pm
Thanks much - same location on my Tug.
But where is the alarm sensor located? Assume it is in the engine room but I don't know where.
Bosn Mate
State/Province: NJ
Postby knotflying on Sun Dec 30, 2018 10:44 am
Not 100% sure, but the sensor is usually located near the front of the engine on port or starboard.
knotflying
City: Charlestown
State/Province: RI
Ranger/Cutwater Model: R-27
Vessel Name: (2011) Illusions
Postby Bosn Mate on Sun Dec 30, 2018 5:28 pm
Thanks Mike.
I found the electronic float switch - is this also the high water alarm sensor? I thought the two were separate.
Mike
Bosn Mate
State/Province: NJ
Postby aculverwell on Sun Dec 30, 2018 8:21 pm
On my boat, there are 2 seemingly identical electronic sensors attached to the forward bilge pump. I was told that the 2nd one is the sensor for the high water alarm.
aculverwell
City: Carnation
State/Province: WA
Vessel Name: Red Sky
Postby rackline on Sun Dec 30, 2018 9:02 pm
It's probably different on our 2009 29 - ours is the identical Johnson electronic switch as the one used and mounted to the forward bilge pump. It's convenient because you can test it by placing a finger in the two circles. I've had to replace the forward bilge switch. Our high water alarm switch is probably mounted too high and should be closer to the forward pump switch height. If the forward pump is kicking in I'd like to know there is an issue with the rear pump.
rackline
City: Marshfield Hills
State/Province: MA
Non-Ranger Model: 17' Finestkind, previous Friendship Sloop
Vessel Name: Headway
Postby knotflying on Tue Jan 01, 2019 9:07 am
Bosn Mate wrote:Thanks Mike.
Mike
There should be two, one is for the pump, the other for the alarm.
knotflying
City: Charlestown
State/Province: RI
Postby Bosn Mate on Tue Jan 01, 2019 6:04 pm
Well......I had my aha moment and figured it out.
The forward bilge pump is a Rule 1100 with a built-in float switch that checks for water every 2.5 minutes. Aha - then why is there a float switch for a bilge pump that doesn't require it? After tracing wires thru the bundle, I found that it wasn't connected to the bilge pump. When I put my fingers on the float switch, the alarm went on.
And my apprenticeship on Ranger Tugs continues!!
Bosn Mate
State/Province: NJ
Who is online
Users browsing this forum: No registered users and 4 guests
