Check your secondary bilge pump and high water switches
Re: Check your secondary bilge pump and high water switches
Postby captstu on Sun Jan 06, 2019 11:13 am
I used Rule-a-Matic model 35A
Well suited to my R25 because the base can be separately attached in the bilge and the switch snaps into the base after wiring.
Been reliable for 2 plus years
Stuart Bell
Ranger 25: Shearwater
(561) 352-1796
Stuart Bell (561) 352-1796
stu@Shearwater-sailing.com
R-25 Shearwater IV
captstu
City: Delray Beach
State/Province: FL
Vessel Name: Shearwater IV
Postby captstu on Sun Jan 06, 2019 11:25 pm
I used a 35A. It comes into pieces so you can install the base and just snap the top in. That way the wires don’t get in the way when you’re putting the base on.
R-25 Shearwater IV
captstu
City: Delray Beach
State/Province: FL
Postby Stormforce on Sun Jan 27, 2019 7:17 pm
Familyguy wrote:Hi All,
Interesting thread. I have the R23 and my switch just failed. I knew it failed because it failed in the on position. I keep the 23 in the driveway (fully covered) and while walking by it one evening I heard the bilge on. Sure enough the unit has failed. I immediately removed it and took it apart (smashed it open :D ), inside the electronics were damp. My bilge is always dry but live in the ‘wet coast’ so I suspect these units are not truely ‘sealed’ and are breathing in moist air as the temp and humidity charges. As an experiment I’m going to use a Marine seal/adhesive and completely seal the unit, I recommend you all do the same.
Exelent plan !!
Stormforce
City: Black creek
State/Province: BC
Ranger/Cutwater Model: R-23
Previous
Who is online
Users browsing this forum: monfried, Mr. Ed and 9 guests
