Use fuses only for dashboard buttons?
Postby jasonpeacock on Mon Dec 31, 2018 1:10 pm
I noticed that the dashboard buttons on my 2017 R-23 have both a 10A breaker on the actual button panel and are connected to a fuse box with appropriate sized fuses for each device/wire size.
Is there any reason to keep the 10A breakers? Could I replace the current button panels with a new panel that does not have breakers? It would be a lot less expensive! :D
Alternatively, if I used a new button panel that has breakers, could I remove the fuse boxes? Though that would require replacing wires and sizing each breaker appropriately, a lot of effort/cost/time.
I'm new to boat electronics, though I've done a lot of non-boat electronics, if there's a reason for using both circuit breakers and fuses together I'm happy to learn about it.
Thanks!
jasonpeacock
City: Bellevue
State/Province: WA
Ranger/Cutwater Model: R-23
Vessel Name: Walrus
Re: Use fuses only for dashboard buttons?
Postby KennyMarrs on Wed Jan 02, 2019 9:48 am
Hello Jason,
The breakers on the top of each switch are for each individual system and the fuse protects the entire panel.
-Kenny
KennyMarrs
Ranger/Cutwater Factory Rep
City: Kent
State/Province: WA
Vessel Name: The Buffalo
Who is online
