Gypsy
- Jan 16, 2021
- R-21 EC
- USFMLC2804F
- Gypsy
I have just gone through rectifying the Garmin Steering Problem. I am writing this post because I feel that there are numerous other boat owners that have encountered the problem, gone through fixing the problem, or have the problem but are not sure just what to do.
If your boat wants to turn to port at high speed, and you must continually turn the wheel to the right it, and it is difficult to stay on course, you have the problem. There are two easy tests to be sure you have the problem. First, while the boat is stopped, turn the wheel all the way to the right. If you don't come to a hard stop and you are able to continue to slowly turn the wheel, it is an indication that the check valve in the auto pilot pump is not holding. The second test is to isolate the auto pilot pump. To do this, first locate the pump, then look on the end of the pump for three brass screws. Turn the screws clockwise to close the ports which isolated the pump. See photos. Then run the boat and test the steering (do not use the auto pilot). You should see that the boat steers as it should.
Now, how to fix the problem. Garmin knows they have a problem and have a check valve kit to fix the problem. How do you get the kit? I got mine through Fluid Motion. Contact Tim O'Neill timoneill@rangertugs.com, or Kenny Marrs. They should be able to get you the kit or tell you how to get the kit and tell you who will pay for the kit and the labor to install it and purge the system. Installing the check valve is not complicated. Purging the hydraulic system after the valve is installed is more difficult because of the auto pilot pump. I recommend having a qualified marine repair facility do the total installation. If you need to contact Garmin, it can be difficult getting to the right person. Here is a point of contact: Michael Villaverde
Marine Warranty Claims Analyst
marinewarranty@Garmin.com
The Garmin steering problem has been going on for quite some time. To me, it is a safety issue. I'm surprised that Fluid Motion never issued a notice to all boat owners, letting them know that there is a problem and that their boat might be affected, and what to do about it.
