NancyDancer
- Aug 28, 2020
- C-26
- NancyDancer
2017 R25 SC (297 hours on the Volvo Penta D3. We launched our boat at the ramp after warning it up at idle for around 20 minutes. Oil level checked before launching (it was fine) Motored out at just above idle and less than 10 minutes after leaving marina, the low oil pressure alarm came on. Shut down the engine, went and checked oil level, no oil registering on the dipstick but noticed oil standing in the bilge. Poured in almost 4 quarts of oil into the engine. Started engine and oil pressure came up. Motored slowly back to the ramp with oil pressure dropping. And by the time we got back to the dock the oil pressure dropped almost to zero and all the new oil was in the bilge. Clearly there is a massive oil leak somewhere. From basic visual inspection cannot see any oil leak anywhere above the bilge line. Has this happened to anyone out there? We’ve had no issues with the engine before. Does anyone know if there is a drain plug under the engine that could have come loose or any other points that could have come loose, or where to look for the leak? I’m currently sucking the oil out of the bilge and cleaning it up. Going to try to get under it with a bore scope, but I had to order one and I won’t have it until tomorrow. Looking for any advice if anyone has had similar problems/known issues or idea of points to look at for a leak.
Thank you in advance for any advice!
Andy
Andy
