JerryE
- Oct 24, 2010
- C-302 SC
- FMLT2551C909
- Non-Fluid Motion Model
- R-25 Classic
- Alto
My R-25 has a weird problem with it's new Yanmar 150hp 4BY which was replaced in 2012 (remember that little oil pipe breakage issue…). Got around 70 hours on this new engine.
Upon turning the key to the first position, the glow lamp lights and then goes out and the ear splitting audible Engine Alarm comes on with the display saying "Check Engine" even though the engine is not running. The display offers no other help. The alarm stays on if I re-start the engine until it heats up. Once the temperature reaches exactly 120 degrees (or more), I can turn off the engine and restart it without the alarm going off. Won't work if I try this at ≤119 degrees.
I can run the boat normally, start and stop the engine all day without problem as long as the engine temperature does not sink below 120. Trying to restart the engine while its temperature is ≤119 results in the Engine Alarm coming back on until it warms up to 120 and I stop and restart. I live with the ear splitting alarm for up to 10 minutes until 120 is reached, but this certainly isn't working right.
This problem happens 100% of the time; i.e., it does not fluctuate. I tried disconnecting the batteries to the engine and then reconnecting them thinking that might re-set the ECU. No luck. The good folks from Mack Boring (our Yanmar distributor in New England) were convinced it was a bad heater module, but installing a new one did not help. Any ideas?
