How to access A/C filter?
Postby The Masons on Fri Aug 21, 2015 9:39 am
How does one go about accessing the Air Conditioner air filter on an R27? I assume through the "cave", but is it easily accessible once down there? Thanks.
The Masons
City: Bowling Green
State/Province: KY
Ranger/Cutwater Model: R-27
Vessel Name: Stella Blue
Re: How to access A/C filter?
Postby trailertrawlerkismet on Fri Aug 21, 2015 10:33 am
On our R27 (2012 model) I access the filter under the stateroom bed. There are two panels that you pop out, take the filter material off to vacuum and or rinse off and you're good to go. If there's been a change since the 2012 model or another filter I'm not aware of someone will kindly let us know.
Jim F
Jim & Lisa FavorsR29S Kismet
info@trailertrawlerlife.com
http://www.trailertrawlerlife.com
http://favorsgreatloopblog.com
http://boatus.com/cruising/kismet/log.asp
City: Traverse City
State/Province: MI
Ranger/Cutwater Model: R-29 S
Vessel Name: (2018) Kismet
Postby Rwnorton on Sun Mar 11, 2018 4:24 pm
Can I ask this question again for a 2016 R27? There is no access beneath the vberths.
Rwnorton
City: Charleston
State/Province: SC
Vessel Name: Grand Cru
Postby knotflying on Mon Mar 12, 2018 8:52 am
Ranger changed system types along the line. Yours may be a single unit with return an supply incorporated in one unit. Filters are usually on the return air side. Find your return air and remove the grill. There may be a filter screen on the grill and there may be one behind it.
knotflying
City: Charlestown
State/Province: RI
Vessel Name: (2011) Illusions
Postby Tut on Mon Mar 12, 2018 2:42 pm
I have a 2015 R-27 and I am also trying to clean the air filter on my air conditioner. I can access the unit by removing the wall at the back of the cave, but there is no way I can remove the filter. The unit sits under the passenger (port side) seat and the instructions for the unit show that the filter must be removed vertically from the unit. This is not possible from what I can see. I will be monitoring this posting to see if anyone explains how it should be done. If I find out, I will post my findings.
Tut
City: Jasper
State/Province: TX
Vessel Name: Fixin 2
Postby Tut on Mon Mar 12, 2018 2:53 pm
Correction, the unit is under the floor in front of the port side seat. YIKES!
Tut
City: Jasper
State/Province: TX
Postby Rwnorton on Mon Mar 12, 2018 7:55 pm
Andrew - are you there?
Time for some factory input please.
Rwnorton
City: Charleston
State/Province: SC
Postby Andrew Custis on Tue Mar 13, 2018 1:34 pm
Hello,
This becomes a little different for everyone so you need to make sure we answer the questions per the specific air conditioner installed in your boat. Please email me directly with your specific questions and I will be happy to answer them or get you to the right person to answer them.
Thank you,
andrewcustis@rangertugs.com
Andrew Custis
Ranger Tugs & Cutwater Boats
Andrew Custis
Ranger/Cutwater Factory Rep
City: Kent
State/Province: WA
Postby Rwnorton on Thu Mar 15, 2018 3:30 pm
With Andrews assistance I found mine by removing the panel where the AC exits into the vberth area. From there duct work, cables and a small vertical clearance make the access sufficiently difficult that one will require exceptional motivation to continue. I chose not to. There is a picture in my gallery.
This applies to a 2016 R27
Rwnorton
City: Charleston
State/Province: SC
Who is online
Users browsing this forum: No registered users and 4 guests
