I have a 2019 R23, over this year, the fuel flow sensor on the Garmin has slowly become less and less accurate, and now complete doesn't work. It started on some of our longer cruises I noticed the Garmin showing lower MPG than typical. I confirmed at the pump that it was indeed reading incorrectly - I could not add as much fuel as the Garmin indicated I should. At first, when MPG would drop, if I turned off/on the engine and the Garmin, it would normalize and seemed to work fine for a while, but eventually would drop back down. Now it just constantly shows 0.00 MPG when I'm at cruising speeds. Any idea what's going on or how to fix?
