Hamster
- Oct 8, 2018
- R-23 (Outboard)
- FMLT2314F819
- Tokitae
I'm a bit perplexed on my R23. My house batteries died so I replaced them. At the same time, I installed a battery monitor (Balmar SG200).
My issue is that I do not see any power going into the house batteries on the monitor when cruising. Should I? I do see the power going in when connected to shore power (monitor showed 20 amps coming in when connected).
On a recent trip, my State of Charge (SOC) when cruising at full RPMs for 1.5 hours actually went down. The monitor was showing negative amp draws while cruising, too because the Garmin, VHF and refrigerator were drawing power.
Do others with battery monitors, either Balmar or Victron or other, see that the amps coming from your alternator show up on your monitor when cruising? If so, is it possible that my ACR isn't working to transfer the power from the engine battery to the house battery while cruising? (I did turn the power switch to parallel several times to reset the ACR, if that might have been the problem.)
