Connecting tv to cable at the marina
Ask away with your Ranger technical or pre-sales questions. A Ranger rep will give you the official scoop.
Postby Flyfisher22 on Mon May 14, 2018 12:33 pm
How do you connect the majestic tv to cable at the marina? I have a 2017 R27
Flyfisher22
City: South Portland
State/Province: ME
Ranger/Cutwater Model: R-27
Re: Connecting tv to cable at the marina
Postby Andrew Custis on Mon May 14, 2018 4:30 pm
Hello. Sorry but we do not install cable outlets on our boats. You would need to install a cable outlet and run to the TV for this to work.
Thank you,
Andrew Custis
Ranger Tugs & Cutwater Boats
andrewcustis@rangertugs.com
Andrew Custis
Ranger/Cutwater Factory Rep
City: Kent
State/Province: WA
Postby trailertrawlerkismet on Mon May 14, 2018 7:42 pm
When we had a R27 I ran a coaxial cable from the tv thru the cavities of the interior and into the cockpit thru a starboard side locker. In the cockpit I installed a typical wall plate. When at dock I could then connect a coaxial cable to shore and the cockpit connection and have cable tv. Honestly thou we found air tv to be just as good in a lot of cases... not all.
Jim F
Jim & Lisa FavorsR29S Kismet
info@trailertrawlerlife.com
http://www.trailertrawlerlife.com
http://favorsgreatloopblog.com
http://boatus.com/cruising/kismet/log.asp
City: Traverse City
State/Province: MI
Ranger/Cutwater Model: R-29 S
Vessel Name: (2018) Kismet
Postby HRowland on Mon May 14, 2018 8:29 pm
On my R27 I installed an A/B coaxial switch near the TV to select antenna or CATV. I ran a coax cable to the cockpit and installed a RV style CATV jack with lid next to the washdown pump outlet.
Howard
HRowland
City: Warwick
State/Province: RI
Non-Ranger Model: 2008 Nordic Tug 37
Vessel Name: Catnip
MMSI Number: 368024230
Postby tglen22 on Wed May 16, 2018 9:04 am
On our R29 CB our dealer Pocket Yachts installed an A/B switch behind the door in the cave by the breaker panel and the CATV connector by the shore power outlets. Works great and easy to connect at marinas with cable!
Tom
tglen22
City: Chester
State/Province: MD
Ranger/Cutwater Model: R-29 CB
Vessel Name: Grey Lady
Postby bill46 on Mon May 28, 2018 11:31 am
Here is how we connect cable tv.
First picture is switch behind electronics, second in inside view of connector, thirds outside of connector without weather cover.
Very easy to access behind electronics with door in stateroom on R31CB.
There are larger images on my picture gallery.
Bill
bill46
City: Palm Coast
State/Province: FL
Ranger/Cutwater Model: R-31 CB
Vessel Name: Radio Active
Postby BB marine on Tue May 29, 2018 9:18 am
HRowland wrote:On my R27 I installed an A/B coaxial switch near the TV to select antenna or CATV. I ran a coax cable to the cockpit and installed a RV style CATV jack with lid next to the washdown pump outlet.
Howard
The cockpit installation on our C26 is identical to yours. I installed an addition TV this winter. The cable and antenna switching is similar just multiplied by 2. Works great we get good reception with the antenna. I tested the cable attachment in the cockpit by attaching coaxial from our house ( our marina doesn't have Cable) It works good. The second TV (smart TV) mounted in the V-Berth pulls in marina WiFi so we are able to watch streamed programing. When we are at anchor we use our hot spot and inverter to stream shows and Chicago Cubs! Because of the poor picture quality of the Majestic we only use it for watching the news in the morning while sitting at the dinette. ( Our majestic TV picture quality is only good if we watch it with straight viewing, I mounted a bracket so we can change the angles which helped but it still is average at best)
Brian Brown
Cutwater 26
PORT-A-GEE
portageelooper.blogspot.com
bkb_marine@msn.com
BB marine
City: Lemont
State/Province: IL
Non-Ranger Model: 26 Cutwater
Vessel Name: PORT-A-GEE
Return to Ask the Ranger Factory
Who is online
Users browsing this forum: No registered users and 3 guests
