Deck Light Switch 2012 R27
Postby CaspersCruiser on Sun Jun 24, 2018 10:38 pm
Neither the cockpit lights nor the walkway lights illuminate when the Deck Light switch at the helm is placed in the ON position. Both sets of lights function normally using the switch at the transom door.
Power is getting from the circuit breaker to the Deck Light switch. I bypassed the switch and tried hooking both power “out” spade connectors from the switch (one at a time) directly to the circuit breaker, but neither set of lights illuminated.
Is there an in-line fuse somewhere between the helm and the lights? I can’t imagine this has any bearing, but both downrigger fuses on the Power Distribution Panel have been removed.
CaspersCruiser
City: Goshen
State/Province: KY
Ranger/Cutwater Model: R-27
Vessel Name: Cookie
MMSI Number: 338127866
Re: Deck Light Switch 2012 R27
Postby Larry H on Mon Jun 25, 2018 12:35 am
On my 2014 R-27 the deck light switch at the transom has two positions ( on-off-on). In one position, the deck lights come on. In the other position, the lights only come on if the dash switch is turned on. That way, you can control the lights from either the dash or the transom. If you set it right, you can turn the lights on from the dash, leave the boat and turn them off as you leave the transom, then, on return, turn them on at the transom, and later turn them off at the dash.
It took a while for me to figure this out. Try turning the dash switch on, then either position on the transom switch should put the lights on.
Larry H
2014 R-27
Jacari Maru
Larry H
City: Tulalip
State/Province: WA
Vessel Name: Jacari Maru
Postby knotflying on Mon Jun 25, 2018 6:54 am
My experience is that this is a three way switch at both ends, so just pulling wires and bypassing may not find your problem. One of the switches may have gone defective. My cockpit one has gone out twice and is most likely the culprit since it is exposed to the weather and outside elements.
knotflying
City: Charlestown
State/Province: RI
Vessel Name: (2011) Illusions
Postby CaspersCruiser on Fri Jul 06, 2018 10:55 pm
As usual, Mike Rizzo had the spot-on gouge about the DECKLIGHT switch conundrum. The failure was in the switch next to the transom door in the cockpit. In the troubleshooting process, I spent a lot of time brightening the blades on the back of the cockpit switch and I replaced the female spade connectors on the wiring to the switch with new. Both had a lot of corrosion. That didn’t fix the problem. The failure was internal to the cockpit switch. The cockpit switch is a Blue Sea Systems 8275. I purchased one from Hodges Marine, installed it and the cockpit lights work via both the DECKLIGHT switch at the helm and cockpit switch as intended.
CaspersCruiser
City: Goshen
State/Province: KY
Vessel Name: Cookie
Postby Boatdreamer on Sat Jul 07, 2018 6:08 am
Thank you guys, my switch just went bad and I was looking for the part number. Just ordered it from Amazon.
Tim
Gratitude
Boatdreamer
City: Stuart
State/Province: FL
Non-Ranger Model: 17 Keywest
Vessel Name: Gratitude
Postby scross on Mon Jan 14, 2019 6:13 pm
My turn to have the cockpit courtesy light switch go out. Knew it's a 3way switch and just cruising the web wasn't much help. Back to tugnuts for a search.....
Found both the new Blue Sea 8275 switch here
https://www.amazon.com/gp/product/B005C ... UTF8&psc=1
and two new oval cockpit courtesy lights here
https://www.amazon.com/gp/product/B00J5 ... UTF8&psc=1
This forum is great! Thanks guys!
Vicki Foley and Al Thomas
2009 R25 Classic
"Our Journey"
scross
City: Ashland
State/Province: OR
Non-Ranger Model: 1984 Addictor 190
Vessel Name: Our Journey
MMSI Number: 367719470
Who is online
Users browsing this forum: No registered users and 2 guests
