Chafing Material for Engine Hoses
Postby Bosn Mate on Fri Feb 01, 2019 2:34 pm
I am getting ready for spring projects and one is to install chafing material on wires and engine hoses. I have the material for the wires (marine grade split loom) but not for engine fuel and coolant hoses.
Does anyone have a recommendation on material for the engine fuel and coolant hoses? A search on Tugnuts described blue anti-chafing material but no further description.
Thanks much!
Mike
Bosn Mate
City: Cape May Court House
State/Province: NJ
Ranger/Cutwater Model: R-29 S
Vessel Name: Tingira
Re: Chafing Material for Engine Hoses
Postby baz on Fri Feb 01, 2019 2:50 pm
I had the Factory place the blue-looking anti-chafing material on all the engine hoses for my R-21EC. I forget the specifics of the material used, but maybe contacting RT customer help line might yield the information you are wanting. If I recall correctly when I did ask for this information, RT were hesitant to convey the material specifications as they weren't sure the same material would continue to be used as it was the first time they had done this for the R-21EC.
Barry & Jake-Wire Hair Fox Terrier
SOLD - 2010 R-25 LAXEY
Trade in 2016 Ranger Gray R-21EC LAXEY
Trade in R-27/OB, LAXEY, Hull Midnight Blue
2019 R29 CB IoM LAXEY, Hero Red
AIS 800, Radio Call Sign: WDK7354
Edmonds, WA
baz
City: Edmonds
State/Province: WA
Ranger/Cutwater Model: R-29 CB
Vessel Name: LAXEY
MMSI Number: 368083620
Postby trailertrawlerkismet on Sat Feb 02, 2019 8:27 am
Clear hosing from most hardware stores or box stores can be used. Buy the diameter you need, cut to proper length, split and slip over other hoses you’re wanting to protect and zip tie them tight.
Jim F
Jim & Lisa FavorsR29S Kismet
info@trailertrawlerlife.com
http://www.trailertrawlerlife.com
http://favorsgreatloopblog.com
http://boatus.com/cruising/kismet/log.asp
City: Traverse City
State/Province: MI
Vessel Name: (2018) Kismet
Postby NorthernFocus on Sat Feb 02, 2019 11:42 am
trailertrawlerkismet wrote:Clear hosing from most hardware stores or box stores can be used. Buy the diameter you need, cut to proper length, split and slip over other hoses you’re wanting to protect and zip tie them tight.
This is my solution also. Or any old (non-steel reinforced) hose of roughly the same diameter of that to be protected. Or for smaller stuff just use the electrical split loom.
Dan
Never confuse confidence for competence.
NorthernFocus
City: Anchorage
State/Province: AK
Vessel Name: Divine Focus
Postby fishheadbarandgrill on Sat Feb 02, 2019 12:54 pm
Use the corrugated slip tubing used to contain wiring. Works great and comes on sizes big enough for engine hoses.
Bob Menches
2011 R29
SEA SHANTY
Southport, NC
fishheadbarandgrill
City: Southport
State/Province: NC
Vessel Name: Sea Shanty
MMSI Number: 368069690
Postby Bosn Mate on Sun Feb 03, 2019 8:22 am
Great recommendations from all; many thanks!
Bosn Mate
State/Province: NJ
Who is online
Users browsing this forum: No registered users and 4 guests
