R 23 vee berth fuse box #3 location
Postby Don55 on Tue Mar 26, 2019 3:30 pm
I am looking for fuse box #3. I have already found 1 and 2 behind the dash. My info kit says it should be in the vee berth. I can’t find it. I am looking for it because the bilge pump fuses should be on it. I am trying to find out why the automatic function of my bilge pumps doesn’t work. Other folks on the site have stated theirs had 5a instead of 7.5 fuses. FWIW the manual function works fine.
Don55
City: Fort Lauderdale
State/Province: FL
Ranger/Cutwater Model: R-23
Vessel Name: Merlyn
Re: R 23 vee berth fuse box #3 location
Postby Embermarie on Tue Mar 26, 2019 3:53 pm
The third fuse box is in the quarter birth under breakers and I th the left. There is a removable panel!
Embermarie
City: Kent
State/Province: WA
Vessel Name: Embermarie
Postby Don55 on Wed Mar 27, 2019 9:59 pm
You mean under the ac breakers? Didn’t see it there before. I am away from the boat right now. Will check again when I get back. Thanks.
Don55
State/Province: FL
Vessel Name: Merlyn
Postby jagizzi on Thu Mar 28, 2019 8:22 am
I believe that you have to remove the side panel first. It is a friction fit so no big deal. This is the panel immediately to the left if you stick your head into the quarter berth. It is on the inside of the walkway wall not on the stern stern side.
Jim and Kelli Gizzi
Next Ten
2018 R23
NWesterly.com
Friday Harbor
jagizzi
City: Battle Ground
State/Province: WA
Non-Ranger Model: R-23, July 3rd delivery, yippee
Vessel Name: Next Ten
Who is online
Users browsing this forum: No registered users and 3 guests
