Live 12VDC Wire in Cockpit Storage Locker
Postby CaspersCruiser on Sun Jun 18, 2017 10:58 pm
During the survey of my 2012 R27, one issue uncovered was a live 12VDC wire for a downrigger installation located in the small storage locker under the starboard entry step. The wire and companion ground were discovered cut clean, but not sealed in any way- not even with electrical tape. The 12VDC wire end was heavily corroded. I capped both wires with a wire nut.
I've become acquainted with another Louisville boater who has purchased a new R27 and I checked the storage locker on his boat for the wires and sure enough, there was a clean cut, but unsealed live 12VDC wire labeled "starboard downrigger". A wire nut was added.
Is there port downrigger live wire? If so, where might I look for it?
CaspersCruiser
City: Goshen
State/Province: KY
Ranger/Cutwater Model: R-27
Non-Ranger Model: 2002 Four Winns Funship 214, 1984 Sea Ray 210CC
Re: Live 12VDC Wire in Cockpit Storage Locker
Postby Larry H on Mon Jun 19, 2017 12:09 am
In the port cockpit locker, up under the lip is a wiring bundle that goes thru a tube. The downrigger wire is folded up and in that tube. The fuse block in the port locker has two 40 amp fuses for downriggers.
Larry H
2014 R-27
Jacari Maru
Larry H
City: Tulalip
State/Province: WA
Vessel Name: Jacari Maru
Postby rpmerrill on Mon Jun 19, 2017 5:27 am
I just pulled the fuses, left and right. Thinking someday I'll think of something to wire up back in the cockpit.
rpmerrill
City: Easton
State/Province: MD
Vessel Name: BAY RANGER
Postby CaspersCruiser on Wed Jun 21, 2017 4:45 am
rpmerrill wrote:I just pulled the fuses, left and right.
Best way to handle it. Done.
CaspersCruiser
City: Goshen
State/Province: KY
Who is online
Users browsing this forum: No registered users and 3 guests
