Rub Rail Leak
Ask away with your Ranger technical or pre-sales questions. A Ranger rep will give you the official scoop.
Rub Rail Leak
Postby HappyPlace on Tue Sep 12, 2017 8:51 am
I have a tiny leak in the cave that appears to be coming from a screw holding the rub rail on the port side, where the gunwale water drains off the ledge. I currently have some white vinyl in place to redirect the flow, temporarily abating the issue.
Should I:
a) remove the single screw and put some marine caulk on it, then reinsert?
b) remove the single screw and put some 3M 5200 on it, then reinsert?
c) wait to remove the entire section of rub rail when pulled for the winter and perform (a) or (b)?
d) other suggestions or recommendation?
Any advice is always appreciated!
Al Sr.
Al Sr., Ann Marie & Roscoe
Happy Place
2014 Ranger R31 CB
HappyPlace
City: Lancaster
State/Province: PA
Ranger/Cutwater Model: R-31 CB
Vessel Name: Happy Place
Re: Rub Rail Leak
Postby knotflying on Tue Sep 12, 2017 10:13 am
As a first course of action I would use Lifeseal. Remove the screw and then apply a generous amount on all the threads and screw it back in. I would not use anything as permanent as 5200. If you have to take the screw out later to address the issue further you will have problems removing it.
knotflying
City: Charlestown
State/Province: RI
Ranger/Cutwater Model: R-27
Vessel Name: (2011) Illusions
Re: Rub Rail Leak
Postby DBBRanger on Tue Sep 12, 2017 10:41 am
Al,
I had a leak in the forward cabin that was rub rail related. It turned out to be leakage from pin holes in the fiberglass between the ledge and the ceiling - it only leaked with very hard and long rain showers. I removed the entire rub rail on the outside (both the metal and the plastic backing) and resealed the screws that were behind the rub rail and the screws that held the rub rail on. Apparently, the water was getting into the fiberglass at the joint screw holes and flowed down through it until it exited at a pinhole in the surface of the fiberglass. It wasn't obvious that that was the cause, but my solution seemed to work. After a couple of years, it has continued to stay dry. I agree with Knotflying - use Lifeseal.
DBBRanger
City: Ridgway
State/Province: CO
Vessel Name: Still Crazy
Re: Rub Rail Leak
Postby HappyPlace on Tue Sep 12, 2017 12:18 pm
Thank you all!
Happy Place
2014 Ranger R31 CB
HappyPlace
City: Lancaster
State/Province: PA
Re: Rub Rail Leak
Postby Dale777 on Tue Sep 12, 2017 4:13 pm
HappyPlace,
In case the leak is not coming from the rub rail, consider a leak coming from the courtesy lights on the cabin's exterior just above the gunwales. See this link for a discussion of that issue:
viewtopic.php?f=6&t=4752&p=34616&hilit=caulk#p34616
Dale, My sister's art: http://www.cindydaunis.com/
My edit [] of: "The horn [ocean] stirs memories of fearful things, of powerful things, of noble and beautiful things!" by John Williams. https://www.youtube.com/watch?v=7gztnm6GS9M
Dale777
City: Ft. Myers Beach
State/Province: FL
Ranger/Cutwater Model: R-31 S
Vessel Name: TANGENT (2014)
Re: Rub Rail Leak
Postby Stevan47 on Wed Sep 13, 2017 7:58 am
Hi guys: out of curiosity I was just reading your responses and I thought you may also have some advice for my situation. As you may know, my R21-EC has black rubber strakes on both sides, running from f'rd to 'aft. Screwed onto the outside of these strakes are stainless steel strips, being functional from a strength perspective and also pleasingly aesthetic. Looking from inside of the cabin I can see nyloc s/s nuts and washers, which presumably secure the rubber strakes to the hull with s/s bolts (?) I have not yet attempted to remove the stainless steel strips, however I am presuming they are secured to the rubber strakes with s/s self-tapping screws. The reason I ask this is because I have some slight seepage of water from the f'rd stbd region of the nuts and I think I may have to remove the s/s strip to access the rubber strake securing bolts. Am I on the right track here? Would appreciate your collective thoughts. Kind regards
Stevan47
City: Western Australia
State/Province: WA
Non-Ranger Model: Recently sold R21-EC
Re: Rub Rail Leak
Postby Krisnjamie on Thu Sep 14, 2017 10:00 am
hi folks, a question from a new guy here. in my brief, and far from a complete perusal of this section I have not noticed a lot of response from the factory addressing the questions posted. does the factory normally respond? cheers, kris
Krisnjamie
City: el pescadero bcs
State/Province: Other
Non-Ranger Model: shopping r-29
Vessel Name: ideas?
Re: Rub Rail Leak
Postby Red Raven on Thu Sep 14, 2017 10:25 am
Hi Kris,
My opinion here only. The factory guys can chime in if they disagree. They do monitor the board and will respond if they feel their input is necessary. Typically this would be potential warranty issues, correct misinformation, or the issue is otherwise not getting resolved by the Tugnuts community. They have a lot on their plate and if the Tugnuts community can resolve an issue faster or without them getting involved they are good with that.
Curt and Tracy Johansen
Red Raven
2014 R27
Volvo D3 200HP
Red Raven
City: Coupeville
State/Province: WA
Non-Ranger Model: Sevylor Ocean Inflatable Kayak, Ranger 260 RIB
Vessel Name: Red Raven
MMSI Number: 338190767
Return to Ask the Ranger Factory
Who is online
Users browsing this forum: No registered users and 4 guests
