1995 Ranger 21 Tug For Sale
TF Varley
C-24 C (Sterndrive)
1995 Ranger 21 For Sale: $22,900
The Ranger diesel tug readily combines charm and function. She has the upgraded 27 HP Yanmar diesel, providing an economical and reliable cruise at 6 mph. Perfect for fishing or gentle cruising. Heated pilothouse, Lowrance depth sounder, Apelco VHF radio. Custom mast and boom with sun awning. Many other options. EZ loader trailer included in price. ($22,900). Boat is located in the Jacksonville, Fl..
Additional Specs, Equipment and Information:
Builder/Designer
Builder: Ranger Model Year: 1995
Dimensions
LOA: 21'0" LWL: 18' Beam: 6'8"
Displacement: 2,300 lbs Draft: 2' Bridge Clearance: 6'7" (w/o mast)
Engines
Engine(s): Yanmar diesel Engine(s) HP: 27 HP Engine Model: 3GM30F(C)
Hours: 422:
Cruising Speed: 6 mph Max Speed: 8.5 mph
Accommodations and layout
Enclosed heated pilot house with wrap around windows and sliding door. Below helm and forward is a V-berth with cushions and overhead hatch for ambient ventilation. Two stainless steel ports-- port and starboard. The cabin also features storage lockers port and starboard, with additional lockers below the V-berth.
Deck, hull and sundries
Constructed in cored fiberglass. Non skid pattern molded into side and cockpit decks. White Gel coat with green stripe.
Porta Potti chemical toilet
5 kg SL-Claw anchor on a bow roller with chain rode and nylon line.
Stainless steel bow rail
Stainless steel stern and cockpit rail
Teak caprail around cockpit
Raised Bulwark with chocks
Teak handholds
Kidde fire extinguisher
Automatic bilge pump
Four rod holders
Cushion for engine box
Large lazerette storage locker
Aluminum mast and boom
Electronics and navigation
Apelco VHF radio
Lowrance x25 depth sounder/fish finder
Ritchie compass
Electrical
12 volt DC from two batteries. One automatic electric bilge pumps.
Navigation lights
12 volt dome lights
12 volt utility outlet
Mechanical details
Single 3 cylinder Yanmar 3GM30F (27 HP) diesel with 422 hours. Engine driven cabin heater. The engine is housed in an engine box, with aluminum fuel tank and batteries aft. Teak Steering wheel.
Trailer
1995 EZ Loader galvanized trailer.
Recent work completed
All exterior teak stained
New water strainer
New aluminum 12 gal fuel tank
New exhaust elbow with attached hose
New relay switch on starter
New thermostat and coolant
New belts and various hoses
New solenoid
New automatic bilge pump
All maintenance items including filters, oil, impeller changed per Yanmar Service ManualTF Varley
City: Ponte Vedra Beach
State/Province: FL
Ranger Model: R-21 Tug
Please contact me if you are interested in viewing several pictures of my Ranger 21.
Tim
Price reduced to $21,000. boat is in great condition with only 425 hours.
Based upon feedback from two viewers I have added several pictures to the Photo Album of the Pilot seat in the down and unfolded position. Two people can comfortable sit on the Pilot seat.
Also, I have posted pictures of the rigged sun shade. The sun shade was an option and it is fitted onto the mast-boom. I've only used it 2 or 3 times at anchor. I always run with the mast-boom up except when we are fishing. When fishing I run with the 360 degree light that mounts on the top of the Pilot House.
Tim
Just a heads-up for potential buyers based on our own frustrating experience. Lenders not familiar with the realities of the marketplace are likely to give you a hard time if you apply for a used boat loan. Our 2003 R21 was valued by the bank at...get this...$14K according to the loan underwriter, based on the top line of the blue book with no accessories counted. My first response..."You DO realize that includes an ENGINE?" We were finally able to prevail and qualify, but only after submitting dozens of listings for similar boats and considerable work with our bank agent. Even at that the interest rate was somewhat higher than we were really happy with. Lesson here is do plenty of research before making that down payment. Even with a good credit score (and ours was pretty darned good) the lenders are making it very hard to qualify. All that having been said, I hope that someone who knows more about real value than some bean-counter banker is able to snap up this buy.
Lots on the C-Brats site about this too. The C-Dorys have the same problem...
Charlie
Could you please fill me in on some more info on the engine.
Weebs
Sorry for the delay in responding-we have been away for two weeks.
The engine is a Yanmar GM 30(F)(C) 27 hp with 447 hours. It is the original engine in my 1995 R-21. Beyond normal maintenance (i.e. belts, filters, batteries, oil, coolant, impeller, etc.) the only repairs made have been a new solenoid and starter relay and a exhaust elbow and hose. For oil I use Shell Rotela 30 SAE and for coolant Yanmar Ultralife YG30.
In addition, I have replaced the water strainer, bilge pump, and fuel tank. The engine sounds great, runs strong and is reliable.
I believe it has a new owner .
Marc
Willie's Tug is for sale and about 1500 miles closer to you. 😀
I only say this because I am sure that Mr. Varley's tug sold already.
