BB marine
- Feb 1, 2016
- C-26
- Non-Fluid Motion Model
- Grady White 208
- PORT-A-GEE
I'm looking for some help in troubleshooting the Garmin Autopilot Shadow Drive installed on my 26 Cutwater. It has never worked since day one. I actually was told on delivery day you can't steer the boat with autopilot on. This was after I did try to steer the boat with auto pilot on and the pump started knocking and we lost steering . After a few minutes of turning the wheel back and forth with auto off steering worked fine and I never touched the wheel again with autopilot on. I have piloted other boats with Autopilot and adjusted coarse with the wheel while autopilot was engaged and it worked fine. I always questioned the dealers comment.
I have since learned many of the systems in the boat and in checking the hydraulic system for leaks, came across a shadow drive switch installed in the hydraulic system . I have read Garmin installation manuals on the installation of the auto pilot and installation of the shadow drive and checked the following.
Shadow drive enabled Yes
Shadow drive mounted horizontally , below helm, above pump, in between helm and pump Yes
All air bleed from the system . Helm has a solid stop on a lock to lock turn and has functioned ?
Shadow drive must be mounted at least 12 inches from magnetic sources . It is 12" from auto pilot pump , right next to hot water heater ( I moved the pump 24 " from shadow drive switch ) I talked to Garmin and they said this is a best practice it can interfere if it is that close, but usually doesn't.
What type of steering cylinder is installed on Cutwaters ? I removed the aft seat to inspect the rudder log and grease it and inspected the cylinder . My memory says it is unbalanced ( my memory is not good) Can anyone verify that ? If it is unbalance there is a block that is to be installed on the pump to help balance the hydraulic oil flow. My pump doesn't have it installed. I'm not sure if this is an issue with the Shadow drive but it is supposed to be installed.
Any information on trouble shooting the shadow drive , experience on working on it, or something I am over looking please send my way. Im sure it is something simple . I watched a Garmin YouTube video on the the Shadow Drive and the demonstration was on a 31 Ranger Tug .
Brian Brown
26 Cutwater
PORT-A-GEE
I
Brian Brown
26 Cutwater
PORT-A-GEE
I
