12 volt breaker labeled “aft refer” cb31 2018
Marnis
C-302 SC
Sonny Side Up
Hi all,
After 3 years of ownership I have no idea what the 12 volt breaker labeled Aft Refer does. We do have a small factory installed cockpit fridge. I thought that the breaker was for that, but I noticed on the 110 ac breaker panel a breaker labeled ice maker. The ice maker is an option that would be installed in the same location as the cockpit fridge. Please inform me of the functions of these two breakers on a 2018 CB 31 with the cockpit fridge.
Sonny
On my 2011 Although not marked I had breakers for rear BBQ with I didn't have.... and for the diesel heater I installed they had already had wires and breakers installed. It seems the wiring is simpler to run for all at the factory and just connect the requested options. I used the spare BBQ breaker for a receptacle I added. So to answer your questions I would suspect they are spares.
I believe the 12 volt breaker labeled "Aft Refer" is for your cockpit refrigerator. You can check that by turning it off and seeing if the refrigerator runs.
As Irish Mist stated, the 110 volt "Ice Maker" breaker is probably a spare and not connected.
