Took a lot of water on backing up to fetch a crab pot with the back door unlatched. After getting back to dock found that having the air conditioning breaker(just the breaker on main panel, I wasn't trying to run the air) on caused dock shore power breaker to trip. I'm wondering if the Air conditioning 120 Volt Control Box is low enough to have gotten water in it, and if so could it cause this problem. The water left a ring on the generator about 3" above the bottom. I'm sure that was when powering up the motor. As water would have been sloshing around down there.
If the control box is low enough that it might have gotten water how would I access it to check.
Also during this little adventure if I throttled up to much I would get black smoke coming out of the transom, any ideas what might have caused that?
Thank you for any help.
