I just installed to new 40 w solar panels on the mast and would like to bring the wire down directly to elm where the red master switch is. Can I connect the solar panel wires to the master switch or do I have to go direct to the batteries
ppelland":1g3txebl said:I just installed to new 40 w solar panels on the mast and would like to bring the wire down directly to elm where the red master switch is. Can I connect the solar panel wires to the master switch or do I have to go direct to the batteries
stwendl":m7e0czgc said:Marine units are usually a bit more protected from the water (and salt) environments. I would not use all Rv devices on a boat without considering that environment
