2008 21EC Engine starts, no house
emmy116
C-24 C SE
Scout
Hi—The accessory battery is charged, but I have no juice to the house. I checked the fuses next to the red house switch, and all look ok, and played with the red button in the engine compartment, but no luck. No problem starting the engine. I am in a slip w no shore power, and we have had a lot of rain, pushing the bilge pump. Any ideas? What could be wrong?
Check the breakers in the engine compartment to make sure they have not tripped. Also there is a breaker under the port cup holder. Check that. Do you have cabin light and other 12 volt accessories? You can crank the engine to charge the batteries.
Heck the thin white wire that forms the ground for the ARC. Without it the house batteries are not charged
