2011 R27 bilge float fuse
Irish Mist
Orillia Ontario
R-29 Classic
FMLT2922K011
Irish Mist
Hi all
If anyone has found a hidden fuse for the rear bilge sensor please share. I have checked the 3amp at the battery. It is fine.. I will find it eventually, for now just ran another wire to the battery.. The wire goes from sensor into the wire bundle that goes to the panel. I don’t have my toner here to trace the wire
Thank You
Ranger tends to change things around, but check by the house battery switch. There should be a bundle of in line fuses. That is where the fuses for the bilge pumps as well as other 24/7 items, such as CO detector and propane alarm.
Yes I looked there as well going to do a deep dive and trace the wire.. I know it will be something simple
I have a 2012 R27 and have a configuration similar to what Knotflying describes. There is a bundle of inline fuses right below my Thruster switch. They are black and about the size of a match book. Check out this photo:
https://share.icloud.com/photos/0e73axiqYX46qxsXbL7GXdWMw
HTH, Gary
