2011 R29 Water /holding tank Location
josborne
NA
NA
On a 2011 R29 where is the fresh water tank and holding tank location and access? Thanks
On a 29 2011 was there just one fuel tank as standard?
Fuel tank is under the galley floor and under the water tank. If you open the inside engine access hatch and look aft, I think you will see both tanks. You can also remove the refrigerator and get access to the tanks from that end as well.
There was an outside 30 gallon aux fuel tank behind the engine on the 2011 model.
Thank you,
If you do not want to remove the fridge, you can go in the cave and remove the side panel to see the water tank. But removing the fridge you can crawl in behind the counter and see all. Many have trouble with their vent for the water tank. If you go behind the fridge, check that your vent line is not pinched.
