2014 21 ev, bilge pump replacement
Stewartn
C-24 C (Sterndrive)
Replacing the Johnson 750gph bilge pump. Cannot see where black box electro switch was located. Any help is appreciated. Thx
Stewart Napoleon
Leslie Ann, Greenwich, CT
Hello Stewart,
It should be mounted directly above the bilge pump.
Sorry to be dense. Hesitate drilling holes below water line. Can I use a 5200 type of adhesive? Thx again.
Stewart
Hi Stewart There are two "black box" switches. On my boat, (same as yours) the high water alarm is mounted above the pump near the top of the bilge on the starboard side. It is screwed onto a block of wood that is attached to the side so no need for drilling new holes. The second box which auto-activates the pump itself attaches to a clip at the base of the pump. Google the 750 GPH Johnson bilge pump and you will see pics of it.
I sent you a PM earlier, not sure it you got it or not.
Newf
Newf,
Did get the PM. Thx. Still trying to locate both black boxes. Will adv. Thx again.
Stewart
