Mike Wolff
- Apr 16, 2019
- R-21 EC
- FMLC2846414
- The Wolff's Den
Need advice, I have a 2014 C 28 with a D 4 VOLVO it has 330 hours on it. It has slowly become harder to start. Once it does start running it puts out quite a bit of blue smoke. When I use the throttle only button and give it more fuel it really smokes on the initial increase in throttle. Then it continues smoking. It seems to have plenty of power. My questions are could it be a stuck fuel injector ? If so can it be fixed with an additive or should all of the injectors be removed and sent out for cleaning? If they need to be removed how much would a mechanic typically charge?
One other note about a year ago I had the oil changed and when the mechanic was done I took the boat out for about an hour, upon my return to the dock I checked to oil level and the oil on the dipstick read that it was overfilled past the MAX letters by a half inch. I had the mechanic return and remove the oil down to the correct level, of course he said this would not damage the engine. My question is could this cause my engine to have the problems that I am currently experiencing?
Thank you for any comments.
