2014 Cutwater C-28
Mike Wolff
R-21 EC
FMLC2846414
The Wolff's Den
My 2014 Cutwater C 28 will not steer straight. while underway the wheel has to be constantly turned to the right to keep the boat in a straight line. Also my auto pilot will not engage so I tried to reset it. I did the circle and then tried the zig zag and the boat would only zig to the left and would not automatically go to the right. any advice on this would be greatly appreciated.
Thanks!
There is much written on this in previous threads if you do a search. Probably your pump. There is an easy test you can do to find out.
I had a problem with my autopilot dropping out and then searching for ecu. Easy enough you can unscrew the connectors on the ecu and spray them with contact cleaner and then re connect. This seems to have cured the problem.
Stuart
You may have a couple of issues. This may help steer you in the right direction along with the other responses.
viewtopic.php?f=18&t=15988
