baz":25p3s9m7 said:
SGIDAVE":25p3s9m7 said:
baz":25p3s9m7 said:
What was the fuel burn at 6 Knots ? Thanks... 🙂
On my Yanmar 3YM that would equate to approx 1.5-2 QUARTS/HR.
dave
So with the 18 gal fuel tank that would give you a max of some 36 hours using the 2 quarts/hr... and at 6 knots/6.9 mph gives you a max range of some 250 miles. Using the 1.5 quarts/hr you get 48 hrs and a max range of some 331 miles. Very economical...
Hello Barry,
Hold on for a minute. The numbers given so far are, to me, "test tank" numbers. That means my 21EC burn 1.5-2 qts/hr under ideal conditions. If you operated only on a lake without tidal influence or other significant current your fuel consumption would
more closely match the figures stated.
I routinely run 80-120 miles before refueling. I meticulously record my engine and distance metrics. I average 10.5-11 mgp OVERALL most of the time. I have had fill-ups where my average was 12 mpg. As with driving a car, periods spent idling, running WOT briefly for engine health, and/or traveling AGAINST a 2-3 kt tidal current all reduce the overall mpg or increase the GPH figures. This yields gph AVERAGing 0.55-0.65 gph. I run at 2000 rpm normal cruise. If fighting head current, I may increase to 22-2300. "Fast" cruise (an oxymoron when speaking about a 21EC) for me is 2500. I'm running Acme #224 which is the more aggressive prop and my WOT rpm are 32-3300, maybe slightly higher in freshwater. I trailer my boat and presently have a 'bare' bottom - no bottom paint.
Given the above, I would consider the 21EC "range" to be more like 150 miles which will leave AT LEAST 3 gallons reserve, and, if you KNEW you where journeying that far, you would keep your speed more economical, which would leave a reserve more like 5-6 gallons which gets you closer to the 1/3 cubed rule. It would not be difficult to carry an extra 5 gallon jug or two of fuel if nec'y.
That's just my experience with the Yanmar 3YM powered 21EC. YMMV
dave
